HELP!!!! 2000 Dodge SC/LB No Start, No Prime, New Lift Pump
- Replies 36
- Views 9.6k
AndrewFrias 18 posts
Me78569 6 posts
Mopar1973Man 5 posts
dripley 5 posts
Some of the tests are done with the connector disconnected. The step he lists is to see if the ECM is sending voltage to the apps. The voltage should be present even disconnected.
How are you checking for trouble codes? I would almost bet there is more in there. You could hot wire the new lift pump to see if it works or as mentioned above see if you have voltage going to it fro
Those are ECM related but like ME says dont condemn anything yet. get the codes read. you do have plenty of fuel in the tank dont you?
Year of truck: 2000
Motor: 5.9 Cummins
Mods: None...
However, I just had the AC guy evacuate and refill the AC to his spec.
How is the truck primarily used: Just used to go to work, however, i recently purchased the truck from a guy that wasnʻt using it much. Seems like it was sitting for quite sometime.
When did the issue start, and if it's intermittent or all the time: The truck turned off last week thursday, and restarted easily. On friday(7/22) i parked it on a hill(running) and it died. I rolled it down and on the side of my house and now it wonʻt start. It throws a P0123 and P1639 code and wont start for sh!t. I can hear the Lift Pump priming, and hit the schrader valve on the IP to see what the pressure looks like -it kinda trickles out. Havenʻt yet checked fuel pressure, but will do it asap. Also, I tried to reset the APPS because thats what iʻve been told the P0123 code is, but nothing. No start, lots of crank. While I tried to start, I cracked the lines at 1 and 3 and no fuel is coming out of there...
Darn truck sent no warning signs or hiccups. Has been running strong until it went Kaput!
So, today, I checked the truck out, cycled the key, and the lift pump cycled. Replaced the lift pump, and now... NO CYCLE! When I was replacing the lift pump, I noticed the fuel line was rather dry. The in and out lines both leaked no fuel which is rather odd, given the last time I replaced a lift pump, I lost some fuel. I am dumbfounded that the cycling is not happening...
Thank you all in advance for your help...
Aloha,
Andrew
