Steering Gear Adjustment
- Replies 74
- Views 24.5k
leathermaneod 36 posts
Wild and Free 11 posts
dripley 10 posts
Mopar1973Man 8 posts
The different brands and tread patterns wont matter except in handling. Unless you are racing around you probably would not notice any difference. I should have stated circumference instead of diamet
Tread pattern isn't really an issue. Like Dave said it's the circumference that is the big thing. When its different from left to right on a differential then the spider gears are rolling constantly.
Give Ryan @ Bluetop gears a call and he can walk you through it, His cell # is 701-301-1256. I will not touch steering gears anymore knowing more about what is inside and doing it correctly from visit
Hey guys,
Most of you know that I recently did A LOT of work on my power steering system, including attempting to rebuild the gear box, which failed forcing me to replace it with a reman. Anyway my trucks steering has never been what I would call very bad, but it's always had the usual 10-2 dead spot. The new box and shaft and even Rock Solid Ram Steering Fix bushing did nothing to help that, though the bushing did get rid of the clunking. I am also guilty of sanding the bushing a little too much to prevent binding in cold weather and so I still have a little movement in the shaft. Anyway I got tired of the dead spot and read up on the "over center adjustment". I tightened the screw about 1/8-1/4 turn max. It helped some but I still had a dead spot. After some more research I found quite a bit of emphasis on performing the bearing preload adjustment BEFORE the over center adjustment. Anyway I ordered a spanner wrench and finally performed the bearing preload adjustment after returning the over center to the way it was. Now I was able to turn the nut about 1/4 turn max before it got tight. So I backed it off about 1/8 turn to halve the total movement. It definitely reduced the dead zone and the steering still feels fine. My question is, do I tighten up on the preload more even though there's only about 1/8 turn left? Or do I now adjust the over center?
