- Replies 8
- Views 9.1k
The_Hammer 4 posts
bjytech 1 post
Cowboy 1 post
TFaoro 1 post
Popular Days
Smoke isn't power.... I'd start by turning the star wheel a couple clicks and sliding the plate back. Are your EGTs high?
I would start by tightening the star wheel up till it gets to where it doesn't smoke at full throttle and gives good throttle response as the boost comes up, if once you get the smoke tuned out it see
As far as how much they can be tuned, this is full throttle from 1200 RPM with an HX35 and 5x13's. (I would recommend 480P minimum). I found I needed a stronger AFC
I had my truck tuned pretty good with the stock injectors and would only lightly haze at WOT. Now that I've added 5x.012 injectors I smoke like a freight train from 1/2 throttle on up with the stock HX35. My question is how much smoke can I expect to tune out without loosing too much performance? Is it just going to be smokey until I upgrade the turbo or should I be able to clean it up pretty good?
