- Replies 26
- Views 9k
crgjhnsn 7 posts
Mopar1973Man 5 posts
dripley 4 posts
015point9 3 posts
Best off going direct plumbed to the gauge. Very few people have gotten an isolator to work right and accurately.
I got the big line kit from Vulcan and ordered a tapped tee along with it. It is installed about half way between the filter canister and the VP. I did not use a snubber, i have the valve barely crack
As far as getting everything you need to install... I questioned that also. I e-mailed a pic to Vulcan and he sent me everything what I needed. Great service. He also told me about (and I bough
My truck is a 2001. I have an older AirDog, and an ISSPRO electric fuel gauge. The issue I'm having is that when I first bump the ignition I get about 15-16psi of fuel pressure. Then running, or even if you let the pump shut off and then rebump the ignition, the fuel pressure goes up to 26psi. I really need to get my test gauge on it, but two different sending units and gauges have been put on it, and both read the same. I was wondering if anyone has any ideas of what I should check? Is it the AirDog, that's marked as being regulated at 15 psi, did I screw up with how I installed the gauge? Any input would be greatly appreciated.
Also, the AirDog was on before I pressure gauge was (I know shame on me....), so I do not know if this is a recent change or has always done it.
