So I just got done replacing my vp44, after I was getting (hard start or so I thought I'm 50/50 with this I don't know if it was my starter and cables or actually a hard hot start) I got the new one in, checked all connections, made sure the key way is in the groove, and started putting everything back together. Got it started once to have the starter go out the next startup.... Put new starter in and all new cables, I finally get to test drive it. ( I also have a wire tap) so I went for a test run..... And to me it doesn't feel like it had the spunk like my old pump did. ( if that makes any sense) I'm 100% sure of this because I lost about 7 psi of boost.( with old I was getting 37 on high side, new one I'm only seeing 30-31) I am double checking for boost leaks tomorrow on my exhaust side, my clean air side is good. So my question is, how the hell does a vp44 vary in that much of a power difference??? Is that even possible ??? I know the new one I put in has been/had something done because it doesn't have the clear gel like the other one does.
Something feels weird, VP44
- Replies 29
- Views 6.4k
fuze24v 11 posts
Mopar1973Man 6 posts
dripley 5 posts
Me78569 5 posts
That's where mine came from is Industrial Injection thru Eric. I called industrial injection before I bought and they said they never would ever send out a rebuilt VP without a brand new PSG board.
Still not right... With so many dealers out there selling VP44's with new PSG units. Why would you pay for VP44 with a "used PSG" that is even bit more more in price than a VP44 with "new PSG" for le
Electronics might not be calibrated to the mechanical part. Timing, fueling, etc. As I've shown the PSG isn't flashed till 3 hours of calibration and all test have passed.
