Questions after coolant change
- Replies 17
- Views 4k
dripley 7 posts
leathermaneod 7 posts
IBMobile 2 posts
Me78569 1 post
Popular Days
Did you run the heater? A good bit of fluid can get stuck in the heater I wouldn't worry about the ratio, I am never exact with it and it is fine.
Nothing! There is no heater control valve in this system. The engine coolant flows through the heater core when ever the engine is running. This is way it is important that the blend door functions
Don't worry about that. If it's need it will be there and if it's not need it will still be there.
Hey all,
so finally got around to changing my coolant. It went fairly well. Started with draining as much as I could through the rad drain. I parked my truck facing on my slight downhill slope and then jacked the rear up as much as I could. Unfortunately I only got about 4-4.5 gallons out. Anyway, then I closed the drain and flushed with garden hose for a few mins on high idle until the water coming out was flat and no longer foamy. Open d the drain at the end just to flush that a little as well. Then shut off the water and let the truck run for a few seconds til water stopped coming out the upper rad hose. Then shut truck off and allowed to drain. Next put thermostat in and closed everything up. Next added one gallon of straight coolant(green from Napa) to the top of the rad. Then mixed coolant 50/50 with distilled water. Anyway I've only got in a total of about 4.5 gallons so far and that's with the overflow tank almost full. I ran the truck at 3 cyl high idle for a little when we first got the rad filled to try and get the temp up to open the thermostat, but it was registering on the temp guage very quickly, I assume because there wasn't enough water on the sensor yet. So I stopped that and just let it idle for a bit continuing to add coolant to the rad as I could. Then went for a drive. Temps were fairly normal, a little more fluctuation then usual but I was able to watch the thermostat open by the temp on the scan gauge. This was on Thursday evening and I was hoping it would suck more coolant in from the overflow and allow me to add some more coolant to get a better ratio, but even after a few hot/cold cycles it hasn't sucked the overflow down much if at all. Is it normal for it to take a while for all the air to get out? Do you think my ratio is good enough being that I must have had about 1.5 gallons in still and only did one gallon of concentrate before doing the 50/50 mix? Sorry for the long post, thanks in advance!
