2001 24 VALVE 230k miles p0122 Maybe vpp
2001 I just got from dealer, auto btw, test drove it drove fine they had a new lift pump installed that day, well I made it home and the next day I took it to work , well it sits at the yard till I get off so I get there and I go to ride a round and take my buddy home, well leaving DAIRY QUEEN, to go to CHEVRON to get some fuel since gauge doesn't work , DEALER sent new one btw will get tomorrow aswell as a TIMBOS tps but I paid next day and kinda got screwed if you order wrong, anyway, going from dq to chevron the truck dies as I am turning to a pump, ok drop in N then stop then P then try to start it fires up, ok well I add 25$ , eventually filling tank up later, but as I leave and I'm going about 3 /4 of a mile away from gas station it does it again, JUST DIES!, well not sure the codes at that time it was throwing , ive done several things, as take back the lift pump just installed and get new one, seeing it wont come on at times but Ive read on why, and when I uninstalled chip It through some VP CODES that mean death but I rehooked and reset and they all went away and it still has the start and sometimes if you do apps reset you get 30 minutes but if truck has been ran you may make to DRIVE out of REVERSE, and JUST DIE!, ok well I said **** it may be TPS Or VP who knows I'm a 12 VALVER, well I tested TPS ITS GETTING .337 at idle into #3 pin,  and it goes up and down smoothly!, well after testing TPS/ APPS  the truck would run good and stuff but then eventually just shutoff, and actually now it sometimes just surges and then lets it idle and it runes fine then will die or surge no idea I try not to drive it! but before it would JUST DIE, and I'm not sure if the ASD Has anything but sometimes if P0122 comes up and I crank 1388 ASD code comes, up! idk PLEASE Help should I just buy a VP I have the TIMBOS coming tomorrow, but as of today I took TPS off , looks kinda new or been tampered it broke loose easily and wasn't very dirty! well now it surges a lot more in 2nd , BUT not original issue, Original issue is the truck just DIED didn't idle , so not TPS ? and Now it just surges sometimes, PLEASE HELP, BTW I also tested a differen plug I believe ground and pin next to it ? well it read 4.670 volts and slowly dropped ? anything there ? just don't know why truck just dies!
Edited by ItzReckless
  • Replies 48
  • Views 10.6k
  • ltz.     I mean this kindly, bud.  I would like to see you happy and able to fix your truck.     To effectively do that, it would be courteous to us and would make people more moti
  • Caps was accidental ,sorry . As far as truck its running but shuts off when something gets warm enough:(
  • You could just hot wire the lift pump, not the VP, from the battery to see if stays running. You also need to know if that pump is putting out any pressure while it is running. You can hook a test gau
ltz.
To effectively do that, it would be courteous to us and would make people more motivated to help you if you try writing as clear a response as possible.  Writing in all caps is understandable sometimes, for really old farts, but isn't necessary here.
This is a written dialogue with us being 24 valve enthusiasts, who like to help others.  It is easier if you answer questions, and keep things as clear as posslble.
I know you are capable of communicating clearly and taking the time to give this community the respect they deserve for helping you.  It is a good group of dudes.  If you can't, you can leave.  You aren't 85 years old and illiterate.
Edited by CSM
I wouldnt start it again until you figure out the fuel lift pump.  You will kill or further damage the injector pump.
You could just hot wire the lift pump, not the VP, from the battery to see if stays running. You also need to know if that pump is putting out any pressure while it is running. You can hook a test gauge to the shrader valve on the VP inlet to test it. Not sure if you have already tried this.
Trucks currently at a very sought after mechanic , if the vp 44 is gonna fail it's not gonna do it because of me , this mechanic should find it very quickly , I told him issues like it'll run fine fires right up this morning,  then after running temps it dies, you people telling me to diagnostic the lift pump itself brand new , so I'm not going to change it in and replace once more , my concerns at this point would actually be the suction in tank stopping the pump up and getting it warm,  any ways guys appreciate help maybe this automotive tech will fix it
I Sound so stupid I mean electrical issue causing pump to turn off
Lift pump is directly controlled by the ECM so that means there should be an error code possibly like P0230 code. Still need to test the alternator for excessive AC noise issues. Being there is no fuse or relay controlling the lift pump.
well man could the CPS cause it, atm the trucks at the mechanic but idk anymore, I drove it just fine to his shop turn of and left kinda on slant! well it wouldn't start , but it seems as if he got it started now because it has been moved, but still same issues!
one more question guys I belive my return line next to the FACTORY lift pump is leaking I see fuel build up! would that cause my issue
The return line goes back to the tank, it should not be under that much pressure to see a rapid leak.
Also, what is your fuel pressure to the VP44? I know folks have asked.   You can check with the tapped banjo bolt off the fuel filter housing.
https://www.genosgarage.com/product/vulcan-test-kit/fuel-system-accessories-replacement-part
Do the codes keep coming back once you reset with your OBD II scanner?    Also, the behavior stemming from the temp at 190 and the problem with it dying when shifting into drive seem ECM related, .    Have you done checking of the ground connections?  My 2001 has a habit of electrical issues unless my battery negative terminal is tight.   Have you check the ASD relay, or replaced that yet?
Good luck
Good luck
everything except check pressure , which is good until vehicle dies then pressure just stops so whats point in checking it doesn't cut out
I understand PRESSURE is key to these I will go buy a pressure gauge kit from oriellys if they have one I'm beginning to thing ecm
Good luck
codes have stopped except 1388 and sometimes 1389 idk
A leaky return line will cause hard starts. It allows air into the fuel system allowing the fuel to flow back to the tank. It should not have anything to do with the engine shutting down at temp.
On 9/22/2016 at 11:12 PM, dripley said:
Ignore accidental quote
Guys trucks running fine after new ground terminal , but I got on it after a corner and it kinda surged a little I may have been tripping,  but the air tube in tank im gonna inspect today
Truck won't start gets fuel to injectors
But 1689 Code Comes UP BUT I pulled relay
Got into vehicle,  WAIT TO START  came on it fired right up,  is this pointing to ecm
Now truck won't start it died while driving again Felto lack of power but everything's on 1388 is appearing,  but I've checked everything
truck restarted , drove a little, CHECK GAUGES came on and I think I hear a weird alternator noise batterys wont charge
I may have fried my alternator idk
Alternator fuse was blown my fault,  but checking ac noise , ready to give up
Hey drip I got the truck running but it still just shuts off till it gets ready to turn back on, I don't wanna waste my money but should I just order a ecm and see if it's theasier fix
Before you spent $800+ on an ECM that may or may not fix your issue, have you checked to see what FP you lift pump is putting out?  What were your results for testing the alternator for AC voltage?
My voltmeter is reading before I connect to something so I'm not sure it's acurate it reads .020  ish. Then I connect to negative and.then the power off alt and it is .054 ish. But I'm scared reading is wrong,  but I think it is ac noise , ive been looking for a fuel pressure gauge, excuse double post,  bad service
I agree with @Hawkez on the ECM. Pretty pricey part to just throw on and hope it fixes it. Is your WTS light delayed in coming on? A few post back you mentioned that you pulled a relay and then turned the key and the WTS light came on and it fired right up. Which relay did you pull?
I figured that the wait to start only comes on when it wants , trucks driving fine now , n actually its idling except , I was just cruising and it tried to die so I put in neutral and it literally died and started back up itself , I'm going crazy because I can't find a damn gauge , I guess maybe the stock lift pumps is going out after just replacing,  I don't get it
Btw alternator is testing good 14 volts
Well idling I could hear it trying to die so I shutoff before it did but idk what a causing it to do that
It's pointing towards the flp, but what's causing it to not send fuel
Who knows mechanic said IP  or ecm never once diagnosed further
Idled still until I shut off few seconds ago
