2001 24 valve
Guys help,  I have just purchased a 24 valve and drove 230 ish miles, next day it just died pulling from dq to a gas station,  I added fuel and started truck it ran and idled fine, get going down road make right turn go 300 yards and it dies no idle just dies, well I removed edge ez, eventually rehooking, earlier today it would start and run then surge , eventually just die, now p0122 p1388 cam up, well, I reset everything even messed with apps,  well noe it don't just dies again and is throwing the asd no signal code 1389, but I don't know, any help appreciated  , thanks,  edge is removed bte
Edited by ItzReckless
  • Replies 4
  • Views 1.5k
  • Thanks.  Spam will be locked.     Keep all traffic on this in the below thread.
Need to deal with the P1389 code first thing... The ASD relay will shut down the truck if the PCM/ECM require it too. APPS sensor might cause a dead pedal but will not affect the ECM ability to idle still.
So what's causing the asd to get hot enough to shut down fuel lift pump and fuel system relay
I checked pcm and all wired looked great , switching relays only fix it temporarily when vehicle is at running tempature
Btw the 1389 code only comes on after the asd p1388 and p0122
Guest
This topic is now closed to further replies.
