P1689 - 1999 Ram 2500 - Idle @ 800rpm & start easy- touch pedal rpm jumps to 1400????
- Replies 52
- Views 16.8k
balesray 25 posts
Me78569 13 posts
Mopar1973Man 6 posts
dripley 6 posts
GUESS WHAT!!!! Charged the batteries a couple hours each disconnected, hooked them back, engine cranked over half dozen time and kicked right off. GUESS AGAIN!!!! Truck is now running like it shoul
Are you still on the original VP? And are you still running the stock style lift pump? The reason I ask is my original VP went at 75k though it acted differently than yours. My ECM went at 217k and on
The oe lift pumps were not a great design. They are notorious for not providing enough pressure for the VP causing them to fail. I did not learn any of this until after I lost my ECM and joined this f
Found this trouble a couple of places but no for sure solutions. Mileage on truck is 87,453 and is stock all the way. No trouble in the past. Just Oil, filters, tires and battery. Bought new in late 1999. Old and retired but I like my truck and need to fix it soon so help. Replaced the lift pump and filter, checked the APPS voltages and are OK, engine starts quick and idles perfectly. Touch the accelerator pedal and rpm jumps to approx. 1400 and that is all. Foot off pedal, goes back to idle. MIL (engine light) on & all other lights work normal. Wait to start on and times out as usual. Code P1689 is all that reads. HELP PLEASE.
