  Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
  Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
  Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
  Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
  Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
  Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 294.6k
  • Quadzilla Power
    Quadzilla Power
full timing at full duration at low rpm can hurt things, but up top I am not so sure.about it.  our trucks have a long drawn out injection event.  I think I read someplace that at full duration and wiretap at 3000 rpm you get something like 100* crank angle of injectioon event.
I really think your gasket issue was just luck of the draw though. during normal driving I would not expect a vp truck to give enough timing to blow a headgasket.
if you compare the typical tune I see with the quad you are actually running now where near as much timing as say a guy running a smarty on timing levels + edge combo.
what tune where you running?
im running my own custom tune based off all the researched ive done through this thread and several others. it runs beautifully and is faster than it should be for the numbers its making IMO. i can post up the tune if you would like
I would like to see it. that will allow me to give a guess as to if it was too much timing resulting in the gasket issue.
I dont see any reason why that would be too much timing.  I ran a very similar tune in sub 0 temps towing.    If that timing curve was an issue, people would smarty S03's would be blowing headgaskets going to the store.
only difference in timing is my low throttle timing,  yours is 1.5* higher.  yours prob results in ~21* at cruise maybe 22* .  little on the high side, but duration would be tiny at that point.
Edited by Me78569
i was also doing wide open throttle pulls 50-100mph and making 70psi. im sure the head gasket was to do with the more than likely crazy cylinder pressures i had with pushing that much boost through that little charger. the only thing that bugs me is that timing rattle/pop that was going on. it would only happen at pretty much WOT. a few other times i got on it 50-60% throttle and it took off just fine. I just talked to a guy at PDD. (yes i know alot of people dont like them for some reason, but i do) and he doesnt think the timing should of really "increased" any from the cold air,  but he laughed and was surprised i didnt blow my charger with that boost.
Edited by cumminsVP2001
If it happened at WOT I see no reason timing was the issue,  nearly every edge truck on the roadis running nearly the same timing curve, if not more aggressive.  I think it was just hte headgaskets time to go.
timing pop might have been telling you too much timing up top, but I flat out abused my truck during the testing of V2 and had more timing pop than most guys and never had an issue.    Not a great thing to do to the truck, but doesn't worry me overall.
Edited by Me78569
im just hoping i didnt cause any head or cylinder damage. the head gasket was just done last summer when i put the studs in. I need to get a drive pressure gauge and/or wastegate at 55psi. i know im out the efficiency range at 60-70psi
do you have a graph or know what the timing is on say an edge or smarty? before the quad i had a smarty stacked with a tst powermax3 and the quad feels like i added a good amount of power. even my first time i drove it after got it installed (before i had the tuning down) i went WOT and my fiance said "that seemed faster"
you picked up power because of timing.  the Smarty does 18* at WOT and peak duration.  you gain alot of power by upping timing.
highest timing im seeing there with the smarty on any setting is like 20* correct?
looking at the quad logs it seems to be around that 30* area at wot
no, 24* - 26* unless you are at %100 duration in which case, on any level other than sw3, timing goes static to 18* regardless of rpm
Edited by Me78569
Yes and less than stock.  Again the edge maxes out timing at 32* and it holds the hp records.
what is less than stock? what is the vp hp record?
18* is less than stock at 25* max.  The VP record is 1000 something on fuel.
guessing monster pump? happen to know SO?
it was stainless diesel, you can look it up.  I dont remember exactly.
  On 11/20/2018 at 3:05 AM, cumminsVP2001 said:
reason i ask is because ive looked on and off, just looked again now. and i cant find it
