Why would a draw straw be abandoned?
I dropped the fuel tank today to clean up extra hoses and tubes and fix a small leak at the sump.   I had no idea I had so much stuff on top of the tank.  The end of the straw is probably a match head of inch from bottom of tank.
What is your best guess of why a draw straw would be installed one day and next day after installing it says he is going to install a sump?
Thanks
  • Replies 22
  • Views 6.3k
1 hour ago, notlimah said:
Yea that's exactly what mine looks like. If his is OEM then what is ours?!
It is the in tank pump module. That thing cost me over $900 and they kept the old module so I never saw it. If you loo closely at it you can see the pump in the basket.
@015point9 I am assuming that is the OE basket but I dont know for sure
That would make sense Dripley. When I modified my fuel module to run the drawstraw 5 it already had the in tank pump installed by the PO and dealership. I know all too well about those pesky little pumps stuck down in that plastic contraption! :mad:
