Stutter/ throttle cut out at low speed
- Replies 5
- Views 2.5k
Mopar1973Man 1 post
JAG1 1 post
TFaoro 1 post
Royal Squire 1 post
Popular Days
One thing I wanted to mention that is on the list of reliability is do not, whatever you do, put in the Dodge APPS.which is expensive and built so bad it's a piece of junk. Put in the Timbo APPS, a lo
Thanks everyone for the responses. Yes I have a fuel pressure gauge but unfortunately it just stopped workin about two weeks ago. Before it went out the pressure always hovered about 12psi at idle and
Hi everyone im pretty new to the whole forum thing as you can tell. I have been having some issues with my truck recently and cant seem to figure it out so that is what led me here as i know mopar1973man is a very reputable person throughout the forum community. I have a 1999 2500 24 valve automatic with the dreaded VP44. The truck is stock other than a five inch straight pipe. When I purchased the truck the man told me that the IP had been replaced before an gave me that receipt which says it was done around 150,xxx. Earlier I went out and started my truck let it warm up for about ten to twelve minutes an went on my way might i add it is around 48 to 50 degrees here where i am. Well after i pulled out onto the road i was going up a small incline and the truck stuttered like it was missing then stopped for a moment then did it again all in the span of about ten seconds. Immediately after the check engine light came on once i got to where i was going i left the truck running then drove straight to my local auto zone an the truck ran just fine at idle and under acceleration (never got in it to much) the whole way there. When the man came out to plug in the scan tool he cut the truck off plugged it in and turned the ignition on and could not get a code so he had me start the truck an he tried again still no code so im left scratching my head. The truck hasn`t done this that i can recall even in just the few times i have went out jumping in and firing it up an taking off without letting the truck warm up for more than a minute around these same temperatures so im a bit worried with check engine light coming on that my IP is failing. Any help, informatin, or advice would be greatly appreciated
