Quadzilla Adrenaline Economy and MPG
Since @Me78569 and company have the tuning thread for performance side. I'm going to start the ecomony and MPG thread for the Quadzilla Adrenaline. I'll be posting up my MPG logs and all data I can provide of what I've got going on. I've been keeping hand math logs of all fuel purchased as well as my tablet running OBDII link LX and data logging from that direction too. I'll share my tunes and settings as well.
QUADZILLA TUNES CURRENTLY LOADED (Check back often file is updated at random times)
Quadzilla Ardrenaline.xlsx
  • Replies 431
  • Views 158k
    Finally!!! Yeah!   Broke 21.06 MPG. Finally got the tuning figured out. 297 miles and filled up with 14.096 gallons giving me 21.06 MPG. This is still with winterized #2 diesel and winter co
    I've learned a lot so far.    Light Throttle Load Limit (Percent) - Mopar1973Man Suggested Setting 25%   This value should be built around the 65 MPH speed on flat ground. That is
    Now that I've returned to the wiretapped crowd now I can see the difference between CANBus only o Wiretap. Of course, the power is way better tapped but I want to find out if I can reach higher like I
I don't think that is accurate.  I think mikes MPG numbers went up  because the OBD link was expect x amount of TPS = x amount of fuel.
Remember OBD Link is just like the Quadzilla showing ZERO TPS signal during cruise control so TPS values isn't considered at all. GPH is calculated from MAP sensor readings.
So if your boost tuning % is higher on your performance tune then the map = gph will be off per tune you do.
IE if you cruise at 5 psi and your tune setting at 5 psi is 105% on your performance tune it will read one way vs your eco tune with might cruise at 5 psi but only be %103 of oem.
the OBD link will only be calibrated to 1 tune.
Made major changes to both tunes. I know for sure than the previous performance curve starting at 105% and 1.8% growth just had a little bit of smoke but clears fast. EGT's spike rather quickly at 1,300*F now. Really getting serious power out of the Quadzilla. So I jumped even higher on the performance side to a full 2.0% growth rate.
So knowing the limits of the performance side now I can back down the economy tune making it nearly smokeless now but getting the widest fuel map possible without smoke. Again I'm going to back down my timing curve I'm not like I'm racing but looking for a quick burst of power to pass other vehicles and such. My first post is updated with all my current numbers.
As for my 2.0% fuel curve on the performance side I'm really loving that tune. Stupid powerful now, just a bit of smoke but it clears right up. Also liking my lighter timing curve. Topped my old HP and TQ numbers. I'll post later tonight.
Timing... You really have to think about all your conditions. Fuel cetane, driving style, IAT temperature, injector sizes, etc. I'm starting to hear the timing and what works best. I've heard tales of old mechanics being able to time by ear... Well I'm figuring it out.
FEBRUARY FUEL LOGS
Nearly 4,000 miles later. +0.59 MPG gain over last month. I will admit I was playing with the performance tune on the last two trips and having a bit of fun. So you'll see a bit more down turn on my off days... So you can see I was playing hard... :whistle: Now if you take notice to the double fill on Feb. 4 you notice that the logs are nearly right on. That was during my period of calibration. But i'll do another here shorting after I'm done playing with my Economy tune and getting the timing set up. Now at 21-22nd you see my error crept back in...
Being the price of fuel is sprung up on me I need to knuckle down and get this tuning done for the Economy tune. So play time is over. Time to start hitting big MPG numbers again.
Current mods
8x.011
62/68/.84
Quad ADRv2
BHAF
ATS Bigfoot t4 manifod
Pusher intake
Raptor 150gph
4" exhaust
Mild tranny
ARP studs
So I found out my truck doesn't like 20.5*-21.75* at 55mph and 70mph. I dropped to 19.1 mpgs on my roadtrip this weekend. I netted 19.79 i believe a few weeks ago on the same trip when i was having timing issues caused by a secret tuner. My max was 19.2* and it went down to 18.8-9* at 70mpg. ME helped me get that sorted out the past week. Thanks again. So this tank i think I'm going to drop it down to 5.5* of advance so my 55mph is around 19.5*.
Hey ME, has the rpm that cruise timing engages change at all? I don't remember what version i had before i updated but before Cruise would lock in around 53mph. Now it engages at 56mph. It was kind of a pain being stuck in a line of traffic going 53-55 and not being in CT. Lol
1400 - 2400 rpm
40 -80 mph
stable speed
stable load
stable boost.
Edited by Me78569
28 minutes ago, Me78569 said:
1400 - 2400 rpm
40 -80 mph
stable speed
stable load
stable boost.
...you need 3 seconds of stable everything above to enter cruise state.
So what I've done is build the main timing map as my fail out map which is about 2* lower than the cruise timing.
Hmmm. I'll have to take a look at my exact rpms the next time I take the truck out. Because I know cruise timing went in at 55 where now it won't. Maybe had something to do with that old tuner? Not sure. Ill take a lap tomorrow and see.
It used to be that cruise timing would kick in after 40 mph, as long as rpm where stable,  the new tunes don't allow that as it is too risky to lug the engine that much and allow for timing ot be jacked up.
I have been playing the cruise timing (right now set at 4) and it seems that no matter what it always stays at 15-16 on the hwy doing 75-80.
Post your full tune.  Your not in cruise state.
I am running the same tune that Moparman has posted in this thread.
Be aware I've been updating my tune file as I go along so double check the file again. I'm due to update the file with my last week changes.
As Mike Pointed out his tune has been changing.  I need to verify that you have a tune that makes sense for your driving habits / speed.  I also need a datalog of those 75 mph cruise states to see why you are not going into ctruise state timing.
Without that we are just guessing.
As of this morning 03/07/17 I've now updated my tune file on the first post. I'm really curious if I can hold a even 20 MPG or higher MPG for the week.
??It will be a while before I get a chance to make that run again. If I had the data log at 60mph will that work to? I have the same problem there to.
Edited by 903Dodge
TUNE PARAMETERS
Number of Power levels:  7
RPM Limit:  3200
VALET MODE PARAMETERS
Maximum Valet Mode Power:  20%
PUMP TAP PARAMETERS
Maximum Fuel Stretch: 1800 microseconds
TPS Pump Maximum: 100%
TPS Pump Minimum: 30%
Minimum Pump Tap Fueling Percentage: 0%
Pump Low Boost Scale PSI: 11 PSI
Boost Scaling: 40 PSI
TIMING PARAMETERS
Fuel Load Timing: 1* (Max Load Timing?)
Low PSI Timing Reduct: 3*
Timing Reduct Scaling: 100%
Cruise Timing Adv: 3*
Cruise Timing Boost PSI Limit: 28 PSI
RPM TIMING MAX
1500 RPM: 17
2000 RPM: 19
2500 RPM: 23
3000 RPM: 25
Max: 26
BOOST LEVEL FUELING - CAN BUS
PSI:100
PSI:101
PSI:102
PSI:103
PSI:105
PSI:106
PSI:108
PSI:109
PSI:110
PSI:112
10 PSI:113
11 PSI:115
12 PSI:116
13 PSI:118
14 PSI:119
15 PSI:121
16 PSI:122
18 PSI:126
20 PSI:129
22 PSI:132
24 PSI:136
26 PSI:139
28 PSI:143
30 PSI:147
I had the data log but forgot to back it up when i got home.
I will get one tomorrow doing 60mph
