99 4x4 5speed ecm issue?
- Replies 16
- Views 3.7k
Greenbastard 7 posts
dripley 3 posts
Hawkez 3 posts
SilverMoose 1 post
The 2 codes do not bode well for the ECM. The alternator issue is to much AC current produce by the alternator. Some out of the box do the same thing. AC current is bad for all the electronic. Checkin
Thank you all so much for your support, after extensive testing, swearing, and kicking, I discovered that the electrical connecter to my map sensor was damaged. The 3 prongs were making terrible conta
When @Dripley talks about checking your alternator for AC voltage this is different that having Auto Zone checking the alternator. When you checked your alternator did you check for AC voltage? This
Alright, first off and for most thank you for any and all reply I receive
So I have done a fair bit of Googleing and searching around, and have come up with nothing. Called cummins, called blue chip diesel, and haven't found a single person who has had the same issue happen. I have a 5 speed 99 dodge 4x4 2500 exsb, ts mvp fuel boost Pyro gauge, bhaf, s366, 150 injectors, pusher intake. When I start the truck at any time it INSTANTLY revs to 3000 ish rpm, then drops to 1000. When I push on the accelerator it will only Rev to 1800 or so, and that's it. Sounds awful and produces and incredible amount of white smoke (as in my cul-de-sac is filled as soon as the truck finishes going to 3000 rpm) I have never tried to drive I'm in this condition. I have attempted to reset the ecm by disconnecting my battery cables and turning the key (this worked, I've had the issue for a few months now and it only used to happen every so often, more so after a raining) but that doesn't work anymore. Scanned the codes found a p0606 and a p0602 code. Attempted to clear the code, nil. Nothing. When the problem was very intermittent, the truck drove fine when this didn't happen, but now (tried for over a week to clear this issue including a new map sensor) I cannot get the truck to properly start. I have heard that these trucks do funny things when the alt. Is starting to die, so I will be replacing it with a friend's to see if that fixes the problem. Really hoping that p0606 code is just make believe because 700-1300 for a new ecm is out of the question. I have attempted to start it with the ts mvp disconnected and it doesn't help. Prior to starting the truck takes around 3-5 seconds of cranking. When she is running healthy it only takes 1 second max.
