- Replies 7
- Views 2k
Popular Days
I just shaped it by hand and used the bolts for the stock box to bolt it down. Kept it up off of everything including the AC line. I had to replace that line last summer and the replacement came bare.
A BHAF is a good idea for any stock truck. Not because it helps the truck breathe so much, rather because it does a good job of filtering and last a VERY long time. a $50 BHAF can last
I built a cradle out of some 1/2" aluminum flat stock to cradle the BHAF and keep it off of everything. It was still a little close to the AC line but the oe line was wrapped in foam and aluminum tape
From what I'm reading a BHAF really doesn't give any advantage unless your truck has mods to support it, i.e. more fuel, etc. My plan was to go with a turbo back, 4'" exhaust and a BHAF. I mean it just makes good sense to me that it would be advantageoiuos for the truck to breathe better. Other than hearing the turbo whine (which I really don't care anything about) is there really no reason to do it if I don't have any mods?
Edited by leon
