Heat Exchanger Transmission Hard Line Replacement
Replaced the hard line from the tranny to heat exchanger with fittings and hose, because mine was bent and a pain to line up the threaded ends. $63 from Jegs
-8 AN= 1/2"
Fittings at transmission- 1/4" NPT to -8 AN and -8 AN 90 degree bend push loc
Fittings at heat exchanger- 3/8" NPT to -8 AN and -8 AN straigh push loc
10' of -8 AN(1/2") parker hose
006.JPG.cb89c44a1649fc4d9539e0838d9a92c9.JPG007.JPG.299bf633a8e327c02dbdb51f94367326.JPG012.JPG.0c53709618b0ae6236fe0baf631d5ed2.JPG
  • Replies 6
  • Views 5.3k
i'd throw some hose clamps on there.  I know push lock sare good to a given psi, but trans temp and pressure might push that limit.
  • 2 months later...
How's this system holding up for you? I don't have any issues with mine but this is definitely something to keep in mind in the future.
Only driven it 3 times since doing that, only about 30 mins each time. My sticker expired and I have spongey brakes. Hopefully fixing it this long weekend. They didn't blow yet, double worm clamped each connection.
Nice to hear. Seems there's been a ton of recent threads on how terrible these heat exchangers are and how they're ticking time bombs to take out your trans :think:
