Problem Exporting Logs
Hello @Quadzilla Power,
I've been having an issue since I installed my IQuadBT that I'd like to rectify. For the most part, everything is great. I have quite a few intermittent connection issues but I've learned to deal with them. The biggest problem is the "Failed to Export" message I get when trying to capture a data log, of any size. I really need to do some data logging on my primary device, an Android In-Dash head unit, running version 4.4.4. I can export on my Samsung Galaxy S4 running 6.0.1. However, my tunes are on the in-dash unit, and there is no easy way that I know of for switching tunes back and forth. And all of my tweaks and changes are on the primary device.
The device is rooted,and I ran fix permissions and wiped the dalvik cache. Still no go. I'm ready to try anything except for flashing a different android firmware. Can you guys help me out troubleshooting this? It seems that Iquad can't create the .csv for for export, so maybe there still is a permission issue of some kind. Any and all help is appreciated.
Thank you,
-Kole
  • Replies 44
  • Views 10.6k
  • Quadzilla Power
    Quadzilla Power
    This forum really is fantastic. We love these guys over here.  Also, just as an FYI, kzimmer really did have to do a lot of tweaks to the operating system on his stereo unit to get it to work. If
  • I bought mine off of eBay a couple years ago. It works extremely well. There's only a couple different manufacturers and different chinese companies constantly rebrand them and sell them with their ow
    Ditto...
How much RAM do you have? I don't mean total storage. I'm talking how much software RAM do you have after everything is running. Like my LG G3 phone is only 3GB or total RAM but after being booted up its using about 2.3 GB so there is very little processing RAM left for logs so mine is extremely slow.
9 hours ago, kzimmer said:
Any insight on this @Quadzilla Power? I would very much appreciate the help.
There may be an issue with car android being able to write to files that hte Quadzilla needs for the data export.
I know there are issues that revolve around having the Iquad software on a head unit.
I'll have to double check, I want to say I have around 1.8 GB RAM while apps are running. I don't think this is an issue, since a 3 second log still has the same issue as a 3 minute log.
Exactly what I'm thinking. I would just really like to know the directory and files being written to so I can check read/write mounting and permissions. I'm rooted so I should be able to take care of it if the app developers can just give me a file location. Everything else works great, unless I update it android 5.0.... then Iquad won't connect even though all bluetooth devices work awesome, including my cheap chinese ELM327, even the Iquad pairs, the app just doesn't communicate. Definitely some shortcomings in the app that I would be interested in trying to fix. One thing at a time though, haha.
Oh Man, I wish I could give you all the information. Its not secret, I just don't know it off the top of my head.
One thing may be that you need to have an email setup. Without that, it won't export properly, I don't know why.
I will have to inquire about the directory stuff.
Path...
/Internal Storage/Android/data/com.quadzillapower.iQuad/cache
This is where exports are stored. So you need to export it to something like Email to get it on the directory.
Definitely have e-mail setup on the device already, so I guess that's not my problem, but very good information to have, thank you.
On 5/26/2017 at 1:31 PM, Mopar1973Man said:
Path...
Crap, I found this directory already and made sure I had write access to it. Created a folder inside to be sure. Thank you for your help.
Back to the old drawing board!
-Kole
Edit: Is it possible there is some sort of working directory where it processes the log before it exports to that location?
Edited by kzimmer
It is processed in RAM and stored in internal structures before trying to export. It needs to be exported before going into that directory above.
Interesting. Mine won't make it to that directory, which makes sense since it fails to export. Now... Are there any error log files stored by the app that might point us in the right direction?
Maybe. I know that's a cruddy answer, but some of the builds have a debugger switch and some don't. It will also depend on the OS version. The even cruddier part is that I can't access those logs and only my developer can. Have you been able to "report" when it crashes? That might be helpful in figuring out what's going wrong.
I don't think I've ever seen the option to report. Does this usually pop up when things go wrong?
  • 3 weeks later...
On 6/6/2017 at 7:44 AM, Quadzilla Power said:
Yes, if the app crashes, you will usually get a "report this" button to pop up.
I get plenty of crashes/disconnects, and I've never seen that pop up. About 1/3 of the time I re-load a custom tune I get a notice that the app has stopped. Maybe It's there and I have always ignored it, haha. I have actually been able to recreate one bug. If I load a custom tune, and around 5-10 seconds later go back to the main screen and try to change power levels, the app locks up. Eventually Android tells me the app is not responding, and asks if I would like to terminate it.
@Quadzilla Power, do you have any more suggestions on what I could try to get the log export working? I'm down to try almost anything that doesn't involve a hammer at this point.
-Kole
3 hours ago, Me78569 said:
When you hit the "export tune" or "export datalog" button the Iquad app puts an intent out to the device to ask what programs can handle folder navigation.
If you have a folder app installed you should be able to save those files where ever you like.  Something like fx folder or something.
16 minutes ago, kzimmer said:
Yeah, that works great on my phone. But on mine I can't even get that far. I just get a "failed to export" derp message, with no alternatives. Seems like a permission problem, but permissions are good.
13 minutes ago, Me78569 said:
The permissions on the root much be different on the headunit vs phone
10 minutes ago, kzimmer said:
You'd think so. I ran a fix permissions app, but I wonder if it doesn't go into root permissions...
Just pasting in a short but relevant conversation from another thread.
-Kole
On 26/06/2017 at 8:46 AM, Quadzilla Power said:
Honestly, I don't have any idea why it wouldn't work. I will have to dig in to find out what the steps are and what permissions or settings need to be set in order to export the data-log.
That would be awesome, thanks in advance.
So I decided I would spend a few hours playing around tonight, wiped the device, replaced OS 4.4.4 with a completely different 5.1.1 (which is much nicer btw). Still failed to export...and actually introduced another problem. The Bluetooth on the device is working, shows the quad connected, my phone is connected, all is good. But the iQuad app doesn't see any connected devices. Doesn't make much sense since Bluetooth is working. I'm thinking there must be some incompatibility with the RK3188 processor.
@Quadzilla Power, I could really use some support here. I'm more than frustrated.
In case you're keeping score, I flashed yet another 4.4.4 OS and iQuad can see the device again, back to normal, but still failed to export.
1 hour ago, Quadzilla Power said:
I've asked our developer for information on this, I haven't heard back yet, but he should reply soon.
Excellent, thank you very much.
-Kole
OK, Here is what I've found. The location of the export file will depend on the Android version. The call that is used is the File.createTempFile built into the Android OS. The temp folder moves depending on the version. A typical location for the file is /data/local/tmp/
If you have the ability, you can create a small app that all it does is create a small temporary file using the same call. Maybe it will help you identify what needs to change in the OS build or with our app. If you figure it out, let me know and I will get the change in the next version of the app as long as it doesn't break something else.
As far as the differences between Android 5 and the Android 4.4.4, Android 5 does have special permission stuff, but since the app was compiled and targetting an SDK previous to the Android 5, you shouldn't have to worry about those permissions. However, I'm not 100% about that.
