Intermittent Coolant Loss?
- Replies 9
- Views 3k
Arodrigues29 4 posts
dripley 2 posts
Haggar 2 posts
Mopar1973Man 1 post
Popular Days
Arod, I had a similar issue. It will only leak when the pressure gets above a certain PSI. In the first picture, the pressure is only 10psi. As I pumped up the system t
As you seen in @Haggar post he was using worm gear clamps and most likely over tighten and deformed the hose. This way his leak showed up. I'm still using the OEM spring clamps. If and when the day co
Good day. Over the past year I occasionally open my hood to see dryed antifreeze spotted on my upper rad hose and valve cover. My temp has always been fine, I never really have to add antifreeze to the truck because it looks like the "leak" is more of a spray. Figured it was a bad/old hose looks like the area of loss is always at the horn into the motor. Took Genos Garage up on it's hose discount of April and ordered up new hoses and clamps, installed them, did a coolant flush and things have been fine. A few days ago I got out of my truck to walk into work and there was a puddle underneath, popped the hood and everything was soaked from the same area. I wire brushed that horn the hose connects too and went another 2 days with no mist or drops, and the truck just did it again. What am I missing?
Edited by Arodrigues29
