Front outer axle seal leaking, help
- Replies 11
- Views 2.9k
WiscoRedkneck 5 posts
Dieselfuture 2 posts
jlbayes 1 post
Mariocand 1 post
I don't want to steer you from front locker but from personal experience if you leave it open, less chance for breaking u joints and axles when you bite traction, especially wit oversized tires. I my
Having a friend take the truck and go through the whole front end for 700 we also talked about the selectable full locker he explainded to me the way the truck is used it would be a huge benefit but a
Just a side note, cheaper Chinese winches ( the one I got 12000lb harbor freight ), are more likely to pull more amps, get hot and overload alternator. So when I use mine I use high idle and if need
The outer seal in the drivers side of the front axle is leaking and getting worse. I first noticed this at a hotel a month ago then last night at the hotel we left a puddle on the ground, I know gear oil when I smell it so I know that the axle is leaking fluid onto the tyre and ground. I've done this before but never on this axle or this truck my question's are do you guys know of any tips or trick when it comes to these trucks do I need an axle puller how much time do you reckon is involved in this repair. Any input or advice is appreciated right now is the worst time for this truck to go down with a major repair thanks in advance.
Edited by WiscoRedkneck
