- Replies 8
- Views 2.1k
Mopar1973Man 4 posts
Leaky88 3 posts
JAG1 1 post
Popular Days
That is the most important... The rest are secondary grounds like lighting and horn. Lot of sanding and scrubbing for nothing to gain nothing. Solution is easy reduce the loads o
Just unhook the two wires at the battery. Nothing to tape up not short out if you unhook the power. Leave the solenoid leads alone so not to trip codes.
Hi,
Do not want to wrongly blame ECM much less buy one needlessly. Lot of articles and Truckers say ECM’s rarely go bad.
So, one last sanity check to be sure. My understanding is as follows:
- WTS should “always” illuminate immediately after switch is turned on. (I’m told it indicates computer has “booted” up.)
- Once WTS goes off, I should “always” be able to bump engine and hear LIFT pump cycle for 25s.
Q1. Should the above events take place every single time?
What I know:
Batteries are good. Charged and tested with DEAD Load tester. Alternator is charging. Noise is .03-.04 max. (Not perfect, but don’t believe it’s a show stopper.)
ALL grounds were lifted, cleaned to brightness, greased, and retightened.
Stock truck: Only work -outside of maintenance- is:
Installed:
1) mechanical Fuel Pressure gauge.
2) FASS LIFT pump – relocated from engine to tank
3) “Protected” Isolation relay (NAPA AR272) to power LIFT
Truck bought used. Not 100% sure WTS came on instantly day of purchase. (my BAD)
I know it came on. I would wait for it to go out and then start engine. Truck started and ran fine. Installed FP gauge, discovered low pressure, replaced/replumbed LIFT with Isolation relay, truck started and ran fine. Then, once after it sit for 2 weeks, I discovered the LIFT would not cycle after engine bump nor start. Pump works fine with direct power. Relay swapped, same problem. This morning, I attempted to START truck. Turned key on, it took 5s (1001, 1002 etc.) for WTS to come on. I bumped engine, LIFT pump cycled and built pressure. Turned key off and back on. WTS came on after count of 9s.
Sometimes, I turn the key on and there is no WTS. I bump engine, and there is no LIFT pump action. No Check Engine Light, and NO CODES. Using an ACTRON CP9670.
I’ve looked at BASIC mods done, took a week, reviewed again, and find nothing wrong.
One last question.
Q2. Can anyone speak to a known quality rebuilder?
Thanks.
Leaky
