Truck died in deep water
- Replies 6
- Views 2.3k
Mopar1973Man 1 post
JAG1 1 post
Texas CTD 1 post
BBHD 1 post
Popular Days
Turns out this stupid fuse is acting funky. I was checking all my fuses cause my cluster wasn't doing anything plus my edge wasn't powering up when I turned my truck on. I grabbed it and went to pull
No do not put dielectric grease in the ecm connector cavity, your asking for problems there that's why there is a rubber seal in the engine harness plug to keep water/debris out. Cummins will tell you
Was driving down the road and what I thought was an inch of water turned into a foot or more. Truck just shut off immediatelyand none of the gauges work and my edge doesn't communicate. how long till the stupid ecm dries out? At least I'm pretty sure that's what happened. 98 24 valve
