High idle switch
I can't seem to get my switch to work. I just left a friend and the local dodge house and he varied that the high idle was on. What do I do to get it to work?
  • Replies 13
  • Views 4.6k
  • Can you go into more detail in regards to how you are using it?     Any codes?   Do you have a live data tool to read the sensor data for IAT and ECT?
What version of switch do you have? Does the switch solder to a printed circuit board or do the wires come right out of the back of the switch?
I have the solder I bought it straight from this sight earlier this year within the last 4 months
Any codes?
Yeah, that's a current version setup. Also looks like it's in good condition.
Typically you toggle the mode BEFORE you start. So select 3 CYL or 6CYL for cold start. Then start the truck as normal. It should rise up in RPM within 5 minutes typically. It will not instantly rise up there is a period of time before the idle rises. It will step up slowly in about 100-150 RPM bumps till it reaches 1,200 RPM.
3 CYL will not work if the coolant temp is above 140*F already.
6 CYL should work at any coolant temperature.
If the high idle software isn't enabled it will not engage high idle no matter how long you wait... A lot of people have issues with a Dodge Dealer and getting the high idle enable correctly. Smarty tuner is the easiest just flash a tune then flash back to stock.
Thank you mopar man I have been trying to use it wrong I have been trying to use it after starting. I will try it before I start and give y'all an update thank you for the help
Well it didn't work. I'm goin to have to find someone around ft worth Tx with a smarty that I can throw 50 there way to use it
Do you have a live data tool to read the sensor data for the truck?  that's the easiest way to know if the switch is working or not.
Yes I have a snap on computer I will let you know something I'm 20 minutes
That was with it on 6cyl I didn't get 3cyl
So that is 6 CYL mode. So that means the high idle software is NOT enabled.
Ok. That's what I was afraid of. I will see if I can remedy the situation and let y'all know.
I am pretty sure that you can rent a smarty from DAP for not too much money.
I took my truck to the dealer to have the computer flashed and the idle software turned on.  My switch didn't work so I went back and had them do it again.  It turns out they had done everything right the first time except turn the idle option on.
