I didnt want to mix up the threads by posting unrelated information so I figured I would start a new one.  This thread is for figuring out what works and what you find your truck likes.
I did some more datalogging as of late and found that a more aggressive timing curve later in the rpm band, say 2500 + rpm, seems to pull harder up top.  Previous I was running tunes that maxed timing at 26*.  I took 2 tunes copied them and ran them back to back on the same stretch of road, same conditions.   I was not using wiretap for this so I will leave those details out
First Tune 29* max
Quote
Race 29*
Number of Power Levels 6
RPM Limit 3700
Valet Mode
Maximum Valet Mode Power 35
Timing Parameters
Fuel Load Timing 1
Low PSI Timing Reduct 5
Timing Reduct Scaling 80
LightThrottle Timing Adv 1
Light Throttle Limit 35
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 24
3000RPM 27
MAX 29
Boost Level Fueling - CAN Bus
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
Second Tune 26* max
Quote
race 26*
RPM Limit 3700
Valet Mode
Timing Parameters
Fuel Load Timing 1
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 22
3000RPM 25
MAX 26
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
The interesting thing is the tunes are the same except for the timing above 2500 rpm.  If you look on the graph rpms hit that 2500 rpm mark at about line 20-21, each line is ~.3 seconds so 3 lines = 1 second.    You can see where timing jumps and also where boost jumps.
Now keep in mind the graphs are not exact so take them with a grain of salt, but everything appears to show that the tune with higher timing up top gives faster time to 50 mph, and a faster ramp up of boost.  The higher timing tune appeared to reach 50 mph nearly 1 second faster.
as always studs are a good idea, but I am fairly sure anyone can run this timing above 2500 rpm.    If people are not blowing their heads off left and right with other tuners then there is no reason why this type of timing curve will hurt with the Quadzilla.
Food for thought, open to other thoughts.
  • Replies 477
  • Views 62.2k
  • and a spare room for me to crash in while I tested about 50x different tunes and setups hahaha
  • Close your eyes and click it.  That's how I order truck parts these days.
  • I think with these vp44 trucks, the biggest downfall here is no 2 are the same... I feel like the quality control was subpar. It seems like 5 identical trucks would behave in 5 totally different ways
Here is a short video on my daily tune that starts at 80% fueling with 1250 wire tap.. This is 45 to 75 wot in 4th gear.. Barely even a haze and ungodly power compared to the old injectors...
 https://youtu.be/rKMWUIren9c
I will get more videos in the next couple weeks..this is still with#1 fuel but temps are up to miss 30s (f) so I'll get #2 next fill up
Dang talk about no smoke at all that's very impressive.  Whose 6x.013s did you have previously?
I had contagious injectors.. And I would have smoked out the highway with them in the exact same situation...
And would have had significantly less power
I have not looked at this data log but this is on my extreme setting.. It runs the pump up to the max, lol.. If when I let off I go to neutral, it will die ha ha never had this before but have seen where people do.
extreme.csv
This starts at 100% fuel and up to 150% by 26psi with a 1500 stretch pump tap. It smoked off the line then cleaned up quickly to a haze a little thicker than my last video.. I can't hardly make this thing smoke.. @Me78569can you help me build a "smoke tune" just to see what it'll do? I had one before but It must have been on my other device I no longer use
I just made one.. 150% across the board, 1800 tap maxed at 1% throttle, 0psi, stock timing +1º I'll try it out in a bit to see if it smokes
@Dodgeih Have you tried bumping the timing just a little more in the higher end?  I bet you could squeeze a little more out of the tune if you move 2500 - 3500 up a degree. I'm running some fairly aggressive timing right now and no issues.  Just a thought.
On my daily, or mpg tune I have timing pretty well maxed in all rpm settings with this for the other settings... Maybe I should bump them up, but was kind of hesitant with the 12cm housing on the hx35. Thinking I'm going to put on my 14cm and open that thing up a little!
What are your rpm settings?  I dont know what maxed out means.
Edited by Me78569
On my daily tune they are as high as the slider will let them be I believe..
18
22
25
30
30
I will look up my extreme one..That's the tune I was on for data log.
cool id dorp your light throttle timing,  thats an awful lot of timing at cruise.
Edited by Me78569
@gipperkid   in an effort to not clutter up the Pop thread,
We dont know if trucks act differently.  Honestly unless you are looking at 7 x .012 or bigger I dont know there is a pop to messing with pop pressure.
@Me78569 Ok, actually will be getting 7x.012. I mean there are probably a handful of parameters that effect that anyway.
I just want guys to know they shouldn't be jumping on the pop pressure bandwagon until we know more.....unless of course they are bored and want to mess with it.
we really have no idea as to the long term issues, if any, that result.  we still dont really know if it is even worth it.
Got ya. Definitely something not for a novice like me. Lol!
Edited by gipperkid
I have to ask as it is driving me crazy @dieselautopower what is this nut for that came in the box with the injectors? Am I missing something or did y'all throw this in to confuse me and get a good laugh?
Hahah I kinda was thinking the same thing...mines still on my tool box
I kinda thought maybe it was sized to remove the crossover tube or something. Mines still in the box.
