Custom Quadzilla Tuning R & D Thread
I didnt want to mix up the threads by posting unrelated information so I figured I would start a new one.  This thread is for figuring out what works and what you find your truck likes.
I did some more datalogging as of late and found that a more aggressive timing curve later in the rpm band, say 2500 + rpm, seems to pull harder up top.  Previous I was running tunes that maxed timing at 26*.  I took 2 tunes copied them and ran them back to back on the same stretch of road, same conditions.   I was not using wiretap for this so I will leave those details out
First Tune 29* max
Quote
Race 29*
Number of Power Levels 6
RPM Limit 3700
Valet Mode
Maximum Valet Mode Power 35
Timing Parameters
Fuel Load Timing 1
Low PSI Timing Reduct 5
Timing Reduct Scaling 80
LightThrottle Timing Adv 1
Light Throttle Limit 35
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 24
3000RPM 27
MAX 29
Boost Level Fueling - CAN Bus
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
Second Tune 26* max
Quote
race 26*
RPM Limit 3700
Valet Mode
Timing Parameters
Fuel Load Timing 1
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 22
3000RPM 25
MAX 26
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
The interesting thing is the tunes are the same except for the timing above 2500 rpm.  If you look on the graph rpms hit that 2500 rpm mark at about line 20-21, each line is ~.3 seconds so 3 lines = 1 second.    You can see where timing jumps and also where boost jumps.
Now keep in mind the graphs are not exact so take them with a grain of salt, but everything appears to show that the tune with higher timing up top gives faster time to 50 mph, and a faster ramp up of boost.  The higher timing tune appeared to reach 50 mph nearly 1 second faster.
as always studs are a good idea, but I am fairly sure anyone can run this timing above 2500 rpm.    If people are not blowing their heads off left and right with other tuners then there is no reason why this type of timing curve will hurt with the Quadzilla.
Food for thought, open to other thoughts.
  • Replies 477
  • Views 82.6k
  • and a spare room for me to crash in while I tested about 50x different tunes and setups hahaha
  • Close your eyes and click it.  That's how I order truck parts these days.
  • I think with these vp44 trucks, the biggest downfall here is no 2 are the same... I feel like the quality control was subpar. It seems like 5 identical trucks would behave in 5 totally different ways
The off idle is just a result of the Quadzilla taking over and pulling the signal down. Not a large problem with smaller injectors but as you pull the signal down more the issue gets worse.  I really don't think we have a good fix for it right now.
@dirty830 mine has done that for years, ever since I put in larger injectors. It or worse the warmer the ambient temp.also worse with#1 fuel. I tried to get rid of it for a while. Lee (contagious) and I talked about Few things and tried a few things with no success or further ideas... Funny part is if it does it at 45mph it'll do out until I stop moving... If It does it at 10mph it'll do out until I stop.. No matter how long it takes.. If I coast from 70mph it will lope until I get to a stop..and it appears yours did the same, once you stop it stops... Strange
20 hours ago, Ekillionc9 said:
i have noticed however that it idles most of the time at 15.5 deg timing.
Here's mine after almost 1 hour of city errands today. 16.54°. It's cold outside! Looks like I need to crank up the fuel pressure regulator a hair as well.
As long as it dont die i think i can live with it.
Could you have the boost offset set to 1psi so it never hands fueling off it stays controlled by the quad?
Mine only died with #1 fuel and temps 45ºf+a couple times but that rarely ever happens... And no there has to be throttle input and/or rpm requirements met for quad to fuel, it can't do anything at idle.. What % are you starting your can bus fueling at and how much low boost smoke do you have?
Nope, that's not how the hand off works.
So when you start the truck the quadzilla sets the handoff point at 1000 rpm and tps > 0.  once 1000 is reached the quadzilla will hold onto control of fueling until either tps < 1 or rpms fall below 700 rpm.  Once either of those happen the handoff rpm is set back to 1000 rpm and the cycle repeats.     This way you dont get a fight for control once a condition is met.
that loping you see in the datalogging is %100 the ecm trying to manage engine rpms at idle state without load.  It shouldn't die if it does regularly I would be looking at your injectors or pump.
If you want to help your offidle power you need to make sure you are setting you 0 psi setting high enough.  It might be needed to set your 0 psi at say %70 but your 1 psi setting at %65.   Easiest way to know is set your quad to lvl 1, then adjust you valet mode power until you are happy with the offidle power vs smoke.  Once you find a good % for lvl 1 to feel good then use that as your starting point for your actual tune.
Here are my current settings and level 3 just for the simple fact that stock turbo, no headstuds, and slipping clutch sooo.
I've noticed you have to start the canbus fueling higher like 85. When I lowered it to the 75ish range it would start doing all sorts of bucking when trying to take off.  I got it to the point I could duplicate it over and over. Anti stall would work great from a dead stop but say rolling to a stop sign when you don't fully stop is when it does it. Start bucking a ton and either mash the fuel or push in the clutch and try again. With the settings I have pictured it almost doesn't do it at all. I have 7x11 with idk what pop pressures buy I would think some of the guys with bigger injectors could start at low 80's or high 70's and rudeuce canvus fueling from there to about 8-10 psi range then start cranking fuel back into it. Timing also plays a huge role. I providing my timing but everyone's will be a little different. I had to pull timing a few degrees across the board from where I was at with stock injectors. It's really running great and it's crazy to think how much the quadzilla is pulling the fueling down from stock and it's still pretty quick. Can't wait to get more mods and turn it up.
nice looking tune.  I like to see people setting their 0 psi setting higher than their 1 psi setting, good work!   once you get a bigger turbo and studs then we can play with things more.  You will gain a TON up top by adding timing.   30* by 3k rpm is pretty typical for boxed tuning on our trucks.
The slushbox makes it nice for the 0 psi setting I dont have to worry about that bucking, my starting point for the tune is %65.
Edited by Me78569
I don't even see that much rpm. 2500 to 2800 max. I'm a low rpm driver for sure. Don't really need to rev it out if I don't need the extra power. Ill normally shift at just under 2k rpm.
8 hours ago, Me78569 said:
"I like to see people setting their 0 psi setting higher than their 1 psi setting, good work!   "
This ha.  I need to find a good starting point for my 0... The bucking is pretty bad right now if I ease into it.
29 degrees the morning, no grids, and no issues starting.
17 hours ago, dirty830 said:
When i come off the throttle or even just idling in gear and push in the clutch it acts like its going to die then over compensates and revs up and so on a few times.
If I'm understanding this correctly, the quad is not in any sort of control in your situation. I saw similar results with mine at 365 bar, although I have an automatic.
The addition of factory anti-stall will likely add complication to this. I believe we have basically found the upper end of pop pressure being tuneable with the Quad. To fix these starting and off-idle issues will likely require ECM program changes that we can't do.
So is there anyone with an auto that wants to test / use some staging code?
I ran the testing awhile ago at 5 ish psi and it worked pretty good, but my drivetrain really can't handle 15 psi launches.
the code will manage fueling to try and keep boost at X if mph = 0.    Pretty fun.
Sounds like you need to do another laundry room rebuild...
It's a no warranty on drivetrain parts type of thing. I know the code works haha.
If ( mph == 0 && boostdefuel == T)
then
if ( boost < boost limit)
add fuel
if ( boost > boost limit)
reduce fueling
so really you plant your foot to the floor because you know you are going WOT leaving the light.  while mph = 0 the quadzlla will manage fueling to try and keep boost as the specified amount.
Neat! I'm working the next 10 days (ish) in a row, but I would definitely like to test it after that.
