Custom Quadzilla Tuning R & D Thread
I didnt want to mix up the threads by posting unrelated information so I figured I would start a new one.  This thread is for figuring out what works and what you find your truck likes.
I did some more datalogging as of late and found that a more aggressive timing curve later in the rpm band, say 2500 + rpm, seems to pull harder up top.  Previous I was running tunes that maxed timing at 26*.  I took 2 tunes copied them and ran them back to back on the same stretch of road, same conditions.   I was not using wiretap for this so I will leave those details out
First Tune 29* max
Quote
Race 29*
Number of Power Levels 6
RPM Limit 3700
Valet Mode
Maximum Valet Mode Power 35
Timing Parameters
Fuel Load Timing 1
Low PSI Timing Reduct 5
Timing Reduct Scaling 80
LightThrottle Timing Adv 1
Light Throttle Limit 35
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 24
3000RPM 27
MAX 29
Boost Level Fueling - CAN Bus
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
Second Tune 26* max
Quote
race 26*
RPM Limit 3700
Valet Mode
Timing Parameters
Fuel Load Timing 1
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 22
3000RPM 25
MAX 26
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
The interesting thing is the tunes are the same except for the timing above 2500 rpm.  If you look on the graph rpms hit that 2500 rpm mark at about line 20-21, each line is ~.3 seconds so 3 lines = 1 second.    You can see where timing jumps and also where boost jumps.
Now keep in mind the graphs are not exact so take them with a grain of salt, but everything appears to show that the tune with higher timing up top gives faster time to 50 mph, and a faster ramp up of boost.  The higher timing tune appeared to reach 50 mph nearly 1 second faster.
as always studs are a good idea, but I am fairly sure anyone can run this timing above 2500 rpm.    If people are not blowing their heads off left and right with other tuners then there is no reason why this type of timing curve will hurt with the Quadzilla.
Food for thought, open to other thoughts.
  • Replies 477
  • Views 87k
  • and a spare room for me to crash in while I tested about 50x different tunes and setups hahaha
  • Close your eyes and click it.  That's how I order truck parts these days.
  • I think with these vp44 trucks, the biggest downfall here is no 2 are the same... I feel like the quality control was subpar. It seems like 5 identical trucks would behave in 5 totally different ways
49 minutes ago, Dieselfuture said:
I've used 1500 paper and my fingers on the line with good results, just pay attention and be patient. And make sure you give it time to stop leaking as some fuel is left behind the nut that screws in head and with heat from head fuel will come out pass threads, that's why if you don't have hard starts (I don't think my truck makes a full revolution before it fires up) leave it be for few days. Or something is cracked, like tip of the line.
Its definitely a leak not residual fuel.... Running all the way off the back of the motor dripping off the bell housing
2 hours ago, jlbayes said:
I have a polishing method that works great. I fight my ppump 24v lines every time.
I have sanded starting at 800-2500 with my finger tips multiple times...
38 minutes ago, dirty830 said:
I'm been fighting a surge around 80% throttle. Very noticeable 1st-4th almost feels like the wire tap is coming on but I'm at setting 3. I'm trying to get a good data log of it happening.
Mine does this too.. Sounds identical to what you described. I will data log it tonight... I can even watch it in the boost gauge
It looks like you're completely losing your canbus fuel and everything else follows, unless I'm looking at it wrong
i think what you are seeing is me coming off the throttle. the surge is usually around 75%-80% throttle you can see a spike in the engine load.
1 hour ago, Me78569 said:
Does RPM matter?
Upon further testing it comes on at 3100rpm every time.
So if I look at the datalogs I see that at 3000 rpm and %70 throttle you are sitting at a canbus message of ~800.
This means your are in your light throttle timing area of the map.
Try setting light throttle timing to 0*   or dropping light throttle limit to ~%15
Any White smoke out the tail pipe when this bucking happens?
Here is a "chug" from me.. It comes in between 2600-3100 rpm but I might just be running out of fuel... This is on level 3 on my "extreme"tune.. I actually turned on the cel at the end of this pull. The tach dropped and the light came on.. P0500 and p1693..strange honestly this chugging wasn't as bad as usually
chugcel.csv
Spotted a "bug" kinda. Since your tune is %100 under oem duration when you hit 3100 hard fuel kicks in to keep canbus high as oem duration falls off.
I wasn't expecting a tune like this to happen so I didn't consider it.  I will have a fix sometime tomorow.
and boy does it hard fuel. surprised me the first few times. i did notice it held canbus higher into the rpms i guess thats the hard fuel?
yea once you pass 3100 rpm ecm fueling drops off the face of the earth.  The hard fuel routine looks at tps input vs rpm over 3100 then adds fuel like a coked up ape.  Works well when the tune is above %100 lol.
I'm fairly certain my problem is just that my vp cannot keep up with the fuel demand....
21psi... I don't mean inlet fuel is running out I mean that the vp can't supply the fuel demanded.. Truck will even die when I let off after a hard pullc unless I stay on the throttle or in gear..
