slipped my clutch.
my 08, G56, was slowing for traffic, down to about 35 mph in 3rd. then rolled into it and the clutch slipped, let off immediately, next stop i lowered my programmer to stock from 3.
That said. i'm thinking after 160K my clutch has had enough. i DO NOT want to dual disk. and i'd like to keep it as quiet as i can.
So who to call? do i keep the DM flywheel.? or switch to the other one.
Thoughts...
  • Replies 57
  • Views 13.3k
  • I'd recommend SouthBend.  I had their Con OFE in my '04.5 which was good for 450HP and 1000ft.lbs. IIRC.  I put almost 175,000 on that clutch and it still worked like new when I traded MightyWhitey.
    I'm on my second South Bend Clutch. First one lasted 140k miles roughly and had a lot of hard and heavy use towing and skidding trees.
  • It's a SMF and it's quiet!    The O-HD is a smoother and quieter product than the OFE. I like the way it drives better and the O-HD is rated to hold 425/900 and at my last dyno I was 415/850
while i wait for someone at SB to call or email me back... yeah not happy about that either...
i noticed something, in the morning when the trans fluid is nice n cold thick like honey, it shifts great at a stop, idle, what have you. but after the trans has been driven 5 or so miles, it starts acting up.
food for thought.
anyhow i'm only at roughly 25K on this oil, but i'm going to swap to a different one yet again, might even mix some,
i have 2 qts amsoil MTG, and 2.5 swepco 711, i'm look around this weekend for some mobile 50, if i'm unable to locate some i'll just get more amsoil form local Napa.
it'll also be a good time to install my TDS pto cover to help in the cooling. then i might weld some fins on the other side away from the exhaust.
Your Swepco 711 seems to be the same as Mobil 50 SAE. You might look at Swepco 202 the only thing is I can't tell if it's a GL-4 lube.
I only need 40k miles to reach 100k miles on Mobil 50 trans fluid. So far no issues for me at all.
here's a thought, should i fallow the manual and change at or around the 60K miles? or being that i changed to a gear oil not the ATF+4 push it out further?
local trans shop suggest i change at 25K beings that i tow my 5'er with this truck.
What got me into the Swepco oils is back in my auto cross days my grandpa told me of it. and most of the Porsche driver say it's one of the best you can use. it's great oil for the RX7 and RX8 gear boxes, the 202 in the dif's
i started using them back in the 90's in my dirt bike and sprint car racing.
i'll give my uncle a call and ask about the 202's use in the G56. i know it needs to be a GL-4.
And the Saga continues, Talked with SB, they sent me a new pressure pate, Even though i think it's the pilot bearing issue, Well the new pressure plate did not solve the problem. still won't go into gear at idle, and the problems get's worse when it get's hot.
So R&R again, put stock DMF LUK clutch back in, truck shifts like a dream again. SB is refusing to help me out. stating it's not an issue with their clutch. well. i don't see it that way. How come the factory LUK one works great? it's a different pilot bearing design.
So i'ma have to make a call to my CC and do a charge back. i'm not paying 1200 for defective clutch.
this is what pisses me off people. i'm now just shy of $2G in clutch and R&R to get my stock clutch back.
Wow, that really sucks!
What is the pilot bearing issue?
I have to agree on the sucking. Curious about the pilot bearing myself.
Well everything "Looks" ok. until you start measuring. the machining for the pilot bearing is not centered.
Can't go into to much detail yet, as i have already contact my CC company., but it's not correct, and if SB will replace this then i'll reverse the CC charge back, but right now i have to wait.
Bearing is smooth but has resistance, likely it's fine,
The issue is it drags on the input shaft, not letting the clutch freespin, it' keeps the input shaft turning, ergo making it hard to shift into gear at idle and as you can see from my video posted on the 21'st, impossible to get R without shutting truck off first.
Hmmm... So the pilot bearing isn't centered. So you measured from the bearing edge to a bolt hole?
Well i had a flywheel machined. RNR the trans AGAIN!!! and had the SB flywheel checked thinking maybe my micrometer could be off. well it wasn't. they had some damage on the Flywheel that i didn't really think anything of, it set a high spot of 20 thousandths, So then when they bored the pilot bearing hole it was at a angle of 20 thousandths off and off kilter and to one side by a few thousandths.
So now i have my custom machined flywheel, my southbend okhd friction disk, and the new pressure plate they had sent.
truck drives perfect again. and i don't have to worry about slipping the LUK clutch if i up the power.
i'm happy,
But now it's time to see what SB will do. if they still push back that nothing is wrong, i'll never use or recommend them to anyone.
Looks like it is cracked by the one bolt hole.
My clutch just started randomly not fully releasing this week so I’m thinking it’s time for a new one. Which means I’m patiently waiting to hear what they say. The O-HD has been on my radar for years.
Not releasing typically is a hydro problem unless the throw out bearing is worn or the pressure plate fingers are damaged. :think:
Typically yes, but it doesn't feel that way thou it's only happened twice.
I need to mess with it more. I've always had an occasional issue when stopped and replaced the hydro's with the clutch but that didn't fix it.
Stock hydros or aftermarket?
Did you bleed the hydro before installing?
They are SBC hydro's and they are sealed. The original issue didn't change when I went from stock to SBC hydro's.
I always re-bleed a seal unit way too many time have I seen a sealed unit with air in the system.
