02 Cummins 1850rpm max
- Replies 56
- Views 13.2k
mossyoak71 22 posts
Scottfunk 14 posts
Me78569 8 posts
jlbayes 3 posts
It really doesn't matter which trans you have. I originally had a manual ECM with my Ally. I got a real low stall TC and when I would come to a stop, as soon as the RPM's dip below 800 the manual ECM
HAPPY, HAPPY, HAPPY, DID I SAY HOW HAPPY I AM!!!!!!!!!!!!!!!? Man what a difference it makes, it runs so much better. Even when I come to a stop, it doesn't want to take off. That's the best thing I d
Yes, although I left the vss hooked up, but it just wanted to see the ground at pin 6
I swapped a 02 Cummins into my F250. Mods are, fummins twin turbo kit, 125 DDP injectors, new springs, and arp studs. Also new VP 44 SO pump. Tunning is by quadzilla, but no custom tunes yet. The motor came out of a manual transmission truck, so I sent the ECM off to be reprogrammed for an automatic because of a massive lope. When I got it back, the lope was cured and it idle ok. When I drive the truck, it will only get to 1850 RPM and no farther. Acts like it has a governor on it. I purchased an automatic apps sensor and did the relearn on it and no help. Any suggestions???
Edited by mossyoak71
Wording
