Ecm swap
I am looking for someone wanting to swap ecm's. I have an 02 manual ecm 235hp and I'm looking for someone with an 02 auto ecm that wants to swap. I can confirm the anti stall feature is present and functioning as that is the reason I am looking to swap. Trying to stop this thing in gear is like trying to stop a freight train (Allison 6 speed with extra low stall). It's never had a Smarty hooked up to it, completely stock. Pm me if you're interested.
  • Replies 28
  • Views 8.6k
  • It's a Yukon (same thing just a little shorter wheelbase. Getting the parts to fit in the truck was a breeze, getting them all to play nice has been a chore. I'm not even a mechanic so I just research
Nice looking daughter you have there. I had three notorious 'daughtlers' around here but now all grown up.
Did you do a Cummins/ Allison to your Chevy Suburban?
It's a Yukon (same thing just a little shorter wheelbase. Getting the parts to fit in the truck was a breeze, getting them all to play nice has been a chore. I'm not even a mechanic so I just research the crap out of everything and rely on people I trust to give me good info. I've looked far and wide and haven't found anything close to like it and I'm damn proud of that. Now if I can just get everything wrapped up by winter so I don't have to ride the motorcycle in the ice. I do have proof that an Allison 5 speed can be very easily converted to a 6 speed.?
I could be wrong but I don't believe efilive works with 02 Cummins. If you know something I don't please share. I'm so happy with the truck so far but stopping is pretty important
Calibration not cal.
you can just get it flashed to what you want.
Oh. I gotcha. I would need a vin for that which I suppose I could get by looking at websites that sell salvage vehicles. My Dodge dealership claims they don't know how and the Cummins service shop looked at it like I was bringing a dead rat into their shop. Do you know someone?
Hmmm...my boss has a 99 that he has a smarty for. It's for his backup truck so I'm sure he'd let me borrow it. Will that work? I like the way you think. Do I get a recovery file from Bob Wagner? I had a brief conversation with him at one point about this and he never mentioned this solution. I guess I just figured that meant it wouldn't help. Also, I have no pcm but I do have access to the databus. My tcm has an obd connector and the trans and ecm are on the same bus for the purpose of sharing tps info. Do you think this will work?
Edited by Scottfunk
Opps sorry about that. Yes cal = calibration.
Yes Bob should be able to help with the file you need.
Haven't heard back from Bob yet so I stopped by the Cummins dealer on my way home from work. Happened to bump into the service manager and he said they can bench the ecm and they'll try to just disable the anti stall. If that doesn't work they'll flash it to an auto calibration for me. Hundred bucks.
I'd pay the hundred just to have the anti stall disabled. Everything is working really well right now and I'm afraid I'll be opening another can of of worms going to an auto calibration. I've heard (and everyone has their own version) that an auto calibration might be looking for a tailshaft rotation. I've read stories about guys getting limited to 1900 rpms after a flash like that and I don't need more problems to figure out.
 They Can disable where the engine picks up road speed from the tailshaft in features and parameters right away if they are already hooked up should not charge you any more for changing more than one parameter.
Now going back and reading the post some more I realized you did have an Allison you should be able to in the ECM parameters choose that you have an (auto) Allison transmission behind it and can have a tail shaft speed pick up if your transmission is equipped with one
My tcm and the ecm communicate on the databus for the purpose of sharing tps info like the md trucks do. There was also a wire from the tcm that I was instructed by my tcm harness builder to connect directly to the ecm I believe for that purpose. I'd really like to stick to the manual calibration and just disable the anti stall. The dealer said he just wasn't sure if anti stall was a parameter. Have you ever looked for that?
I don't recall seeing it but I go through quite a few ecms a day more ISC ISL ISX and ISB 6.7 than the older b 5.9s
Fair enough. If I understand you though, if the anti stall use not a parameter then my other option is to go to an auto calibration and have the tail shaft disabled. My only question about that setup would be I am currently using my quadzilla with a 10 inch tablet for my gauge cluster. If the ecm is no longer looking for tail shaft rotation would it still broadcast speed info so I can have a speedometer?
it should, the ecm takes in speed from the abs computer on pin 43.
No abs computer. No pcm. Speed fed to ecm directly from tcm.
I just checked my tcm harness instructions and the tcm does in fact feed speed info to the tcm on pin 43. Do I should be good to eliminate tail shaft parameter?
Edited by Scottfunk
