- Replies 11
- Views 2.3k
								Mopar1973Man 4 posts
								dripley 4 posts
								JAG1 3 posts
Popular Days
								Another idea. Leave the valve alone and pick up a snubber from ISSPro and install it after the valve. This way you can still shut the line down and the snubber does the job of the cracking the needle
								I think you can unscrew the packing nut around the valve stem and remove the valve that way, Instead of redoing the whole thing. Might be a replaceable valve tip needle or something.
Any one know if an Isspro F/P gauge can be disconnected at the back to bleed off the air and then reinserted and retightened without buying a new compression wring? I'm not aware of how the plastic tube is sealed whether a compression wring like plumbing or what
