How much HP will the stock SO vp44 produce before it cannot keep up.
- Replies 12
- Views 5.6k
Mopar1973Man 3 posts
SASQCH 3 posts
dieselautopower 1 post
Wild and Free 1 post
Had an interesting phone conversation with the owner of TST products today about the so vp44 fuel pump.
He was a Cummins employee and has worked on and has had access to testing the vp44 and prior fuel pumps.
He said that the high pressure side of the internal vane pump produces around 300 psi at 2200 rpm engine speed, and that the actual injection is done by a piston that creates the high pressure pulse and also directs it to the correct injector. This piston not only pushes the fuel to the injector but also rotates or spins to line up with the correct injector port in the VP44. He said that many of the pump failures are attributed to the piston ceasing from lack of adequate lubrication.
He also said that when the HP is pushed to high levels by programmers and oversize injectors (100 hp and up) or stacking programmers with the larger injectors, this piston can suffer from an inadequate fuel supply being able to fill the piston for every time it fires the injector(s). This can cause the power to come and go in quick spurts under heavy loading and higher rpms, even with the FASS or airdog pumps of 100 gpm flow. It's not about the fuel to the vp44 this he said can happen with 15+ psi at the vp44 fuel inlet.
He said that the hot-rod pumps that are built have different parts from Bosch that have a larger piston with more capacity, and that they no longer build them.
He also said that when a vp44 is rebuilt that the pump does not have to be put on a test bench and programmed, that the parts are all connected to the electronics and programmed when they get them from Bosch. They have even taken the internals from one pump and put them into another with no reprogramming as long as the electronics are not taken apart and reassembled. It's like taking non volatile memory out of a computer and putting it back into another computer of the same configuration.
So my question is how much hp have people been able to get from the stock so vp44 with injectors and stacked programmers without having apparent fuel starvation?
Thanks
Jim
