Adrenaline V2 won’t load custom tunes
I have a Quadzilla Adrenaline with V2 tuning but it won’t load custom tunes???
HELP PLEASE!!
  • Replies 25
  • Views 10.2k
  • Have you followed my videos for loading a tune and for flashing?    The loading of the tune should only be done on profile 2.5  I am guessing you have a mismatch in data.     I wou
  • Doesthe computer beep when you plug it in?
  • With my computer, windows 7 64 bit, the only way the flasher program will see the box is if I click update (or flash or whatever the button is), and then plug in the usb quickly. If I plug it in then
Yes it beeps as soon as you plug the box in then a few seconds later it makes the sound that the box has been disconnected. But I went through the whole process multiple times and couldn’t get it to work at all
did the device driver install complete successfully or did it fail?  It will print on the screen what happened during hte driver install process.
The only way I can get mine to connect is click the identify (or update) button, and then immediately after, plug the USB cable in. If I plug the cable in first, it almost never works. I also have to disable antivirus (Bit Defender). Try that if the driver is already installed properly.
  • 1 year later...
Hey y'all, so besides the diaphragm going bad in my VP, my quadzilla works great I love it! I downloaded one of your tunes and customized it better for my stock truck, all of the sudden it won't load that specific tune when I turn my app on on my android..... It loads the stock tune, and your towing tune, and another tune I made, but the one I was tweaking and working on for my DD just petered out :duh: anyone have any idea what's going on???
Thanks for any input!
