- Replies 7
- Views 2.5k
The_Hammer 3 posts
Mopar1973Man 1 post
IBMobile 1 post
Hawkez 1 post
Popular Days
The crawfish looks awesome!!!!
I've met a lot of Cajuns and none of them were offended by "coonass". Whoever wrote that garbage on Wikipedia about "working class" and "middle class" cajuns is obviously an idiot.
It all started earlier this year, around March I believe. A friend of mine mentioned that he was going to be participating in an obstacle course called Cola Warrior and that I should try to get a run slot and go with him. I had no idea what Cola Warrior was about so I starter doing some research.
Cola Warrior was started by a former .Mil guy who now works as a contractor overseas. It was designed as a physical and metal challenge that makes you go "WTF am I doing?" Lol.
Basically there are regional events held across the country with the top 10 finishers eligible to compete in the finale dubbed "Cola Warrior Classic".
All of the events have the same basic layout with varying degrees of difficulty:
*There are 5 obstacles and you must legitimately attempt each one
*After the obstacles you have to field strip an AK while eating two rails of Peeps
*After that is a 1/2 mile run
*At the end of the 1/2 mile run is a shooting range with steel rifle and pistol targets
*The last thing is the "chug" where you drink six 12oz carbonated beverages of your choice (no alcohol allowed) as quickly as you can and then hurl.
Obviously after finding out what it was all about I HAD to do it!
I attended the local event called Cola Warrior Texas back in June and placed 5th out of 75 participants. I met a ton of great people from all around the country and made a lot of new friends. The whole thing sounds absolutely insane but after CWT I'm hooked.
Awesome prize pack! This thing revolves around firearms, especially AR15's as those are what you compete with.
The rifle I competed with.
