Block plug boost adapter
Just a quick question. Finally getting my gauges in. Going to get my boost reading from the block plug behind the filter housing. My local hardware has the 3/4 to 1/8 bushing but only in galvanized. Wanted to make sure that was okay or if I needed to get a steel fitting.
  • Replies 6
  • Views 1.6k
  • News flash...toilet flange bolts don't work to good in muffler clamps
  • BTW, aren't you the guy that uses 4'' galv pipe and threaded couplings. for the exhaust.... I think I heard about you
Galvanized fitting can and will still corrode.  Galvanized would work, but I would hold out for a brass fitting.  I've seen cheap galvanized fittings that easily chips away, I would hate to see any debris from a bad fitting make its way into your engine.
Thanks for the advice. I just hit up good old Amazon and found a brass one.
Try ace hardware believe it or not.  Over holiday my regular place was closed...took a chance and found it in plumbing section
News flash...toilet flange bolts don't work to good in muffler clamps:whistle:
BTW, aren't you the guy that uses 4'' galv pipe and threaded couplings. for the exhaust.... I think I heard about you :lol3:
