No pulling power
Hooked up a trailer with one ton of hay and turned down the Juice to level 3. It was very sluggish gettin up to speed on he highway. What should I look for? It was fine after i unhooked the trailer
  • Replies 12
  • Views 2.5k
You should be..  Smoke is unused fuel.
What were EGT's doing?
Boost leak tests?
Trailer up to par? Last time I towed one of the tires had a bad belt and my truck was sluggish hooked up, not to mention bumpy.
Remember gang Edge Juice has main and sublevel tuning. So if the main level is on 3 what was the sublevel? 1-3 sublevel will defuel to a set boost pressure to clean up smoke.
SUBLEVEL
1 - 33% of stock fuel till 20 PSI boost
2 - 50% of stock fuel till 15 PSI of boost
3 - 67% of stock fuel till 10 PSI of boost
4 - Some extra fuel at low boost
5 - Full fuel at 0 PSI boost
Mike,
Those numbers can't work.
The edge on sublevel 1 , if it was %33 of stock fuel, wouldn't drive.
If the edge does pull fuel down below stock it can't be more than %15 below stock.  My truck smoked pretty good even on 5 x 1 when I datalogged it.     It was way dirtier than my quad tune which started at %85 of oem fuel at 0 psi.
@Marcus2000monster do a boost leak test.
If I could find my old Edge Comp manual which I think is long gone those where the setting listed in the manual. As for how they figured those setting and so forth I'm not sure but just reposting what my manual had. As for the new manual they don't even list the sublevels any longer. Do even explain how they work other than less responsive and most responsive.
Now double check the sublevel for each main level. Edge has a bug that levels 4 and 5 tend to bleed the sublevel. So for example if you have 4x1 and 5x5 it will be a dog. If you set 4x5 and 5x1 it will be a smokey pig. Best way to do it is to set all subevels the same this bug will disappear.
I think I had level 5 and 6 on sub level 5 and the rest on 4. Would that still cuase the doginess?
