- Replies 11
- Views 2k
Mopar1973Man 4 posts
Dieselfuture 4 posts
AH64ID 2 posts
015point9 1 post
Popular Days
Ok... I've got an ISSPro EV2 series fuel pressure gauge and got my fuel pressure gauge warning light programmed for 13 PSI. So there is my warning. As for the Quadzilla the last two trips to Ontario m
If you returning warm fuel from the engine and have filters hanging in the wind it going to take the heat out of the fuel. The whole conversation if about Wind Chill or Actual Temperature. The rule st
The wind will lower the temperature of the fuel faster, but it cannot make the fuel colder than ambient air temp. Fuel heaters are great! I have 2 of them and can see them work and warm f
Any advantages to knowing what your fuel temp is? If so, where is best spot to install sensor?
Thanks
