- Replies 37
- Views 6k
you still want to match your fuel to your air. As you move right on the graph rpms are climbing Here's what the oem fueling command % looks like at WOT, note how it peaks at
Exactly I am maxing the fueling duration via canbus commands at peak torque and peak boost ~2000 rpm, but I only using ~400 us of wiretap on my "hot tune" as that is all my turbo can flow. this 40
Question for the quad and injector experts. Im about to pull the trigger on some injectors. Looking at the dfi 7x12, 7x13 and 7x14. Will be installing a 64/68/12sxe next month. From what iv read there seems to be something to detuning a larger injector with the v2 tuning and having a better power band then a smaller injector running at its limit. Question is what is the largest injector a vp can support and what is the point of diminishing return or has this even been tried yet? i used search function but can find no answers. I think i read somewhere that 7x14 was all a sovp could support but cant seem to find it again. Wondering if a injector that larger can be detuned enough to run cleanly and have a better power band?
