- Replies 16
 - Views 2.4k
								Me78569 6 posts
								Mopar1973Man 4 posts
								Dodgeih 4 posts
								BBHD 2 posts
Popular Days
My truck did this Christmas Eve morning as it was -11 F that morning when I started it to leave Colorado. It fired and shortly after as I walked back into the house it went to 3cyl it was like the ant
you know what it is, it's the check in place to decide to fuel or not, If rpms are above 1200 the quadzilla may trigger.fueling. this is in place to allow timing adjustment nad fueling adjustment fo
So it finally got cold enough to kick on the 3 cylinder high idle. After it runs for about 5 minutes I noticed that it intermittently switches to 6 cylinder high idle. I've had high idle for 3 years and this has never happened. When it does it it only does it for a second or less then it goes right back to 3 cylinder. Once it starts it does it 5-10 times per minute. I have searched on many forums with no findings of similar symptoms. Wondering if anyone has any idea on possible causes or has seen any threads with info on the topic.I'm going to attach a data log from quadzilla. It happened multiple times here
3cylhi.csv
Here's a video, can slightly hear it
Hi.mp4
