Steering gear leaking at bottom
- Replies 14
- Views 4.1k
Glenn Perry 4 posts
Mopar1973Man 3 posts
Marcus2000monster 3 posts
Silverdodge 2 posts
Oversized tires tend to put higher stress loads on the steering box. I would call Ryan at BlueTop and ask him for a new end cap and a seal kit and just rebuild the box again. Kits are fairly cheap and
Thanks Morpar1973man, I contacted Ryan at Blue Top he identified the end cap, seal and lock ring which are now heading North. Great contact.
New end cap, lock ring and O-ring installed, flushed the system works perfectly.
Steering Gear bottom domed cover seems to have cracked and leaks fluid. Truck is 175kms steering gear showed very little wear any reason why this might have happened.
Can I get another cover and just replace it or are they matched?
Thanks
