BUG - Quadzilla high idle while rolling
- Replies 20
- Views 4.4k
Mopar1973Man 10 posts
Me78569 8 posts
Dieselfuture 2 posts
thsi one I am pretty proud of this. The offidle handoff is VERY hard to feel now. I can feel it by brake boosting, but not on the street. It has rpm based fueling smoothing an
Flash with the version I posted this afternoon 2.7.6. The high idle state was looking for speed to trigger, but not to cancel. Kinda the same logic as the high idle switch not canceling.
UGH! needed an Or rather than an And when I was looking for speed or tps input to cancel Try again when you get a chance.
This is for sure a bug I'm able to repeat consistently. If I wait the 30 seconds to engage the Quadzilla high idle which it slams fairly violent to 1,200 RPM. After Quadzilla starts high idle I can put the transmission in gear either forward or reverse and let out the clutch. Speed is shown on both the Quadzilla and the dash cluster and the Quadzilla is not canceling high idle.
