Lift Pump Question
If I'm Lucky enough to get a refund from taxes this year I would like to purchase either a DTT Assasin or A FASS Titanium 95 or 150.
My question is must I modify the stock fuel lines or put in a sump if I go the Fass route or can I reroute the stock lines to the pump?
  • Replies 165
  • Views 34.1k
  • I appreciate all of this stuff but after @trreedand @W-Ts dissertation above I think me and the micro Henry's are going to have to sit in the corner for a little while.
  • A fuel heater is going to do absolutely nothing for the fuel in the tank. Do whatever you want but that little tid bit negates the fuel heater in the bowl or on the lift pump.
  • Air separation is a HUGE farce that should not be carried into any decision for a fuel system. Stop it.
23 minutes ago, JAG1 said:
But that's what makes it fun, different, interesting conversation around this place. It's what normal folks do:USflag:.
I can moderate, but why remove the welcoming aspect? The human aspect?
If anything retitle the thread! This is great guys!
Ok, what title would you like Marcus? Anything appropriate.
ASk @W-T Hes running the show now lol.
ANy way to erase the freeze frame data from when my LP died? @W-T Don't be afraid to keep up the good stuff in this thread!
