HELLO EVERYONE, I HAVE A 2001 2500 4x4 SLT WITH A CUMMINS ANYWAY IT STARTED ABOUT 6mnts AGO WHEN THE FACTORY WIRE TIES HOLDING THE HARNESS BROKE. EVERY NOW AND THEN I WOULD GET A CHECK LIGHT FOR APPS OUT OF RANGE.I WOULD UNPLUG AND RESET IT BE OK FOR MAYBE A MONTH AND THEN THE NEXT TIME YOU WOULD START IT BE ON AGAIN. WELL NOW I GET A DEAD PEDAL ONCE IN AWHILE AND MY FUEL MILAGE SEEMS TO HAVE DROPPED. I ORDERERD A TIMPO APPS YESTERDAY I BELIEVE THAT SHOULD HELP IF NOT IT WONT HURT. DO YOU ALL THINK I'M ON THE RIGHT TRACK.THANKS
  • Replies 7
  • Views 2.6k
:cry: You are hurting my ears with all your SHOUTING!! Ask the others, my truck don't have an APPS.
So if your getting a dead pedal and P0121, P0122, or P0123 codes then yeah the APPS sensor is failing... Time for replacement... Oh a suggestion... CAPS is a sign of yellin' some might take it the wrong way...
Or if your like me hard of hearing. lol I could hear him just fine.
sorry guy's i didn't realize i was shouting. thanks mm for helping with forum prodacol tactfully . :thumb1: hopefully the timpo one will take care of it.
Not to be a smart arse.....but just trying to make sure you ask for or look for the correct item. It is called the Timbo APPS
thank you i have it on order should be here tomarrow:hyper:. i would like to say i'm really glad for this forum i have have learned alot thru the theads.
