Welcome To Mopar1973Man.Com LLC
We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features. Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
- Replies 15
- Views 3.7k
Jonny 6 posts
jlbayes 5 posts
trreed 3 posts
Mopar1973Man 1 post
(atmospheric pressure) + (overall boost) divided by (atmospheric pressure) = overall P/R (atmospheric pressure) + (primary boost) divided by (atmospheric pressure) = primary P/R (Overall P/R) divi
I do my math based on wot as it is typically a constant. Your numbers look ok for part throttle operation. I would tighten the gate to try and get the secondary pr to come up as it will help with resp
Yes as it spools first. The primary is what cools everything off once it is up and moving.
Did This Forum Post Help You?
Show the author some love by liking their post!
Hey guys I got a few questions I just installed a compound turbo kit on my 2000 Cummins. My question is why does the small charger need to be set at 25 psi? The lowest I could get it with the Boost elbow is 32 psi when it starts to open, I don't think I can adjust the actuator because it does not have a nut on it. What would the harm be if I just left it at 32 psi? Thanks everybody
