vac pump oil line leak
- Replies 9
- Views 7.2k
Junkman 4 posts
Mopar1973Man 2 posts
dripley 2 posts
Dieselfuture 1 post
I took my vacuum pump & power steering pump off as a unit to seal the PS pump reservoir leak. The oil line is leaking where it connects to the vac pump. There is a threaded piece that screws into the pump itself then the oil line connects to that piece. I put oil resistant piece on the threads that screw into the pump. It looks like the leak is where the nut for the oil line threads onto that piece.
Am I missing an o-ring or something? It looks like it is supposed to be a mechanical seal with metal surface to metal surface but is is a large leak. Removing the line and making sure everything was clean didn't help. Any ideas on how to stop it?
