IQuad V2 tune build
So i just got the V2 and ran it up at ATS diesel an I’m looking for some tune help to get some more power out of it. Truck has 150hp sticks, 64mm silver bullet, studs, fass150. Any help would be greatly appreciated.
  • Replies 12
  • Views 2.6k
Lets start with what you put down at ATS and what tune you ran?   Got datalogs of the runs?
It put down 436hp and 753 torque i used the tune builder set on race. The app crashed after the first pull and didn’t reload until i loaded back up on the trailer
tune builder set to race doesn't tell us much,  can you upload your tune?
On GDP’s dyno it put down 488 and 918
same tune?
Add timing.
1500: 15*
2000: 19.5*
2500: 24*
3000: 29*
max: 30*
will added pump stretch help or hinder?
Dunno,  you might try 1800, are you hitting 45 psi up top?
up there he wouldn't let it build boost before he full throttled it and it only pulled 30 ish.(wouldn't let me run it on their dyno) down here with me runnin it it gets just under 50
so your wiretap wont max until 45 psi in the tune you sent.  You can set boost scaling to 30 and that will make it so you hit peak wiretap at 35 psi.
