Bobbing of idle with larger injectors fix
- Replies 8
- Views 2k
dirty830 3 posts
Me78569 2 posts
Mopar1973Man 1 post
Dieselfuture 1 post
The bobbing when i come off throttle and truck is trying to idle is getting worse with the increased temperature outside and when i have my ac on when it revs up it blows quite a bit of smoke out. It stops when i get to a speed less than about 10mph. Question is could i break the vss line momentarily or ground it out to trick the ecm that i stopped and return to a normal idle?
