Intermittent starting problem 1998 dodge
- Replies 26
- Views 8.5k
Waydin_Stewart 11 posts
dripley 6 posts
kzimmer 4 posts
IBMobile 2 posts
Clutch pedal position switch or starter relay. Next time no start happens, with someone turning the ignition switch and clutch pedal pushed in, test for power at terminal 86, 87 and 30 o
No problem here. Fastest, easiest way, is to swap out relays but if that doesn't work see above.
Hello again, I have had this starting problem for about 6 or 8 months now at least and I'm getting tired of it. I cant find any write ups online about it. Its a 1998 dodge cummins obviously. I don't really know how to describe it cause it is so random and all the lights work and try fires up fine once it finally cranks over. I'de guess about every 40th turn of the key is a dud and then the next 20 or 30 cranks after that are dude until the truck decides it wants to crank over and start. What could this be? I have checked every fuse in the truck that a test light can check. I have eyeballed all the square fuses under the hood. Everything seems okay. It has a new ignition in it, my father replaced it before i got the truck cause he thought that was the cause of the truck dieing(was vp44/ecm) so got new vp44 and rebuilt ecm. I believe it was the ignition anyways. I have the part and the box for the new one in it somewhere. Batteries are new and cable end are new with di electric grease slathered generously. It has a oreileys starter on it. It was put on truck when I replaced clutch as my original one was from autozone. But the shop I was at had an oreileys one in the box so we put it on.
Edited by Waydin_Stewart
