- Replies 13
- Views 3.6k
Tom Robarts 7 posts
trreed 2 posts
Red Rambler 2 posts
SilverMoose 1 post
62-68-12 over a s475-96-1.10
Got the long arms and coilovers, and fox bumpstops installed. While the engine was out replaced all the brake lines with s/s pre bent lines. Replaced ps hoses with a kit from Geno's. New Redhea
Thought I should start a build thread on my truck.
Truck is a 99 ECLB DRW factory Sport pkg.
I will be replacing and upgrading the entire suspension and steering with parts from DOR LLC. As well as a new ps pump and lines from Geno's, red head steering box, borgstein shaft, and ram rock solid bushing.
Installing a 5.9 reman from DFC diesel with upgraded Hamilton valve train, Wagler rods, Colt stage 3 cam, 7x13 sticks, II VP 44, compound turbo's and twin kit from Crazy Carl's, BD billet flywheel, Northern hi flow intercooler, Crazy Carl's intake horn and intake plate. Everything on the engine will be replaced, new oil cooler, altenator, fan hub, fluiddampner etc. Replacing the current Fass 95 titanium with a 150.
For the body, installed new rockers and cab corners, replaced doors with rust free southern doors, installing a rust free southern box. Will be installing a fg visor and a fg ram air heat extraction hood. Installing a custom grill from Karriker Customs.
