Engine loss of fuel after hard acceleration.
- Replies 45
- Views 9.2k
Mopar1973Man 15 posts
Daveb 15 posts
Dieselfuture 8 posts
Marcus2000monster 2 posts
If you got a dealer near you may try to have the ECM reflashed to see if that helps. Typically this a Smarty thing where people see P0602 error codes because the Smarty alters the ECM information. Sin
The hypertech and superchips will produce the P0602 as well. You may have an issue with the edge box based on what faults are there.
THE FIX FOR THIS POST IS HERE!! The issue was a corrupted ECM. Autocomputer specialist in Florida did a great job flashing it and it resolved ALL issues. I had a p602 code which accordi
Hey guys, I figured I'd post to see what you all thought. At completely stock power or with the edge comp all the way up, stock injectors and turbo or aftermarket, it doesn't matter, the truck will die after a hard pull if you take your foot off the pedal. It won't drop back to idle like it should. If you keep your foot on the pedal just a little bit for a couple seconds, it recovers and all is well. It sounds like it's running out of fuel. The airdog never drops below 12psi. The vp has about 3000k on it. It did it with the old vp too. I'd like to understand why if possible.
Thanks.
