- Replies 7
- Views 3.2k
notlimah 3 posts
AH64ID 2 posts
Dieselfuture 2 posts
Popular Days
I don't think it's a bad idea to have oil temp if you tow with above 350 rwhp. I think there is a reason Cummins dropped back to a 190° thermostat and added an oil temp gauge on the 13+ trucks.
Yes you can use tranny temp sensor and T in where oil filter is, but it's a waste of effort, I did it and oil was always about same temperature as antifreeze. About 10 degrees higher then antifreeze f
Yea that looks like where quad tells you to install it so that’s my plan.
Looking to get my quad to read oil temp, but can’t find one actually labeled as such. Pretty sure the sensor labeled trans temp is the same sensor though right?
https://www.dieselautopower.com/quadzilla-power-transmission-temperature-sensor
