Driving home from work engine the tone changed and my max speed was 60 mph so checked for codes no codes, I disconnected the TS MVP no change, I check fuel pressure seemed normal to me bump key 17psi, running 15psi, mash the pedal to the floor 10psi, my fass pump is 12 years old. Truck is smoking white smoke. I'm thinking it the VP44 it have been in for 10yrs and 200,000 miles. It did this the first time the VP44 died, except it would only idle no matter what position the gas pedal was in.
I'm thinking it's the VP44 again just wanted a second a pinion.
I plan on replacing the VP and the fass pump.
Thanks
  • Replies 45
  • Views 6.5k
  • I never get to say this... Your truck went full retard. Lol. Sorry.
  • No.  Quad shows commanded timing.  That's the unfortunate thing with our goofy electronic/mechanical injection system.  We can't see actual injection timing or duration (two variables that would let u
  • That area must be haunted!  There's a cemetery on a mountain back road (basically forestry road) that every time I drove by it, the truck shut off in the same place. Did it when three different people
Might consider replacing tappet cover gasket while you are so close.
Absolutely... That is the best time to do it. It only took another 20 minutes to remove the other tidbit and slap that tappet cover on with a fresh gasket,
It's all back together runs great thanks for y'alls help.
